Thread: Dimming with LED's flaky above 91%
    Nov 2017
    3
    Default Dimming with LED's flaky above 91%
    Hello,
    So for the last few years I have had an odd issue. When above 91%, only a couple channels work and they randomly turn on and off between 92%-99% and nothing turns on at 100%. Additionally, some low intensities below 30 (lights are pretty much off by 30%) glitch full brightness. I've gotten around this by simply only programing between 30%-91% intensities. My setup uses a rennard dimmer (595 converter) and both Grinch and 595 boards. Has anyone encountered this issue before? Should I set up dimming profiles for all my channels? Setting each individually would be a huge pain at over 256 channels. Anyways curious if there is an easy fix for this. We run 100% LED lighting.
    Thanks!
    79
    Default Re: Dimming with LED's flaky above 91%
    Do you use a snubber?
    3,634
    The renard software needs to be updated to use PWM. The LEDs draw to little current to keep the triacs triggered. The PWM mode gets around this.
