Results 1 to 7 of 7
Thread: Unauthorized Access Exception
    Mar 2017
    Lancaster OH
    89
    Default Unauthorized Access Exception
    Am I missing something obvious?
    I put together a simple Christmas show and attempted to test it. As the show started I had green lights on my USB dongle as well as the Controller (Renard Plus LCC16). The show started OK and lights were turning on/off/dimming as expected. About two minutes in the green lights suddenly went out on the USB dongle and Controller. (power light on the controller remained on.) Show preview continued to run without a problem. Checking the application log I am seeing this string of messages:
    11/13/2017 18:53:50.516 [Vixen.Sys.Output.OutputController] An error ocuered outputing data for controller DMX Pro System.UnauthorizedAccessException: Access to the port is denied.
    at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str)
    at System.IO.Ports.SerialStream.BeginWriteCore(Byte[] array, Int32 offset, Int32 numBytes, AsyncCallback userCallback, Object stateObject)
    at System.IO.Ports.SerialStream.Write(Byte[] array, Int32 offset, Int32 count, Int32 timeout)
    at System.IO.Ports.SerialPort.Write(Byte[] buffer, Int32 offset, Int32 count)
    at VixenModules.Output.DmxUsbPro.DmxUsbProSender.Send DmxPacket(ICommand[] outputStates)
    at VixenModules.Output.DmxUsbPro.Module.UpdateState(I nt32 chainIndex, ICommand[] outputStates)
    at Vixen.Sys.Output.OutputController.Update() at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str)
    11/13/2017 18:53:50.646 [Vixen.Sys.Output.OutputController] An error ocuered outputing data for controller DMX Pro System.UnauthorizedAccessException: Access to the port is denied.
    Just to be certain I had the latest version, after this first occurred I downloaded a fresh copy and reinstalled. I'm running 32bit version on W10. Problem occurred again after the reinstall.
    6,993
    Default Re: Unauthorized Access Exception
    Looks like something else is trying to access that port. What other programs are open that might use com ports?
    Mar 2017
    Lancaster OH
    89
    After closing Vixen, Task Manager says no applications are running.
    Sent from my XT1650 using Tapatalk
    6,993
    How about services? Anything that would try to communicate with phones, media players, etc?
    Mar 2017
    Lancaster OH
    89
    Task Manager > Services I see nothing obvious. (see below).
    When I launched Vixen again and went through the same process it started successfully and ran for about 15 minutes.
    I was just about to say 'problem solved' when lights went out again. Double checking in Task Manager the only applications running are Vixen, Task Manager, Microsoft Edge (where I am writing this response), and Notepad.
    Mar 2017
    Lancaster OH
    89
    As it turns out the "problem" with Vixen was a symptom and not the problem. I have a pet not feeling well and had a small heater plugged into the same outlet as the Renard. Apparently it kicked out enough noise as it cycled on off to mess up the Renard, which scrambled the Actidongle, which screwed up the USB port. Unplugged the heater and the schedule ran perfectly all evening. Needless to say, I'll be slapping a noise filter on the Renard when I move it outside.
    6,993
    That's an interesting way for that problem to manifest. Hopefully that's truly the problem and not a happy coincidence.
