Results 1 to 10 of 15
Thread: Power Injection --- Can I skip the T's?
    NM
    67
    Default Power Injection --- Can I skip the T's?
    My setup is similar to this image where I have a 50 pixel strand powered from the controller, and then about 100 pixels directly connected to the end of the first strand. (no power) and powering both ends from the second power supply.
    I know I should use a T for the power injection (circled in the image)... but I don't currently have any... Couldn't I just simply solder an additional wire to the positive power injection (One each for positive and negative) and heat shrink the T-connection with hot glue to help waterproof it? (It wouldn't be so much of a T... but more of a "Y" connection?... like the first wire splitting into 2 "------====")
    notwlights.com
    356
    Default Re: Power Injection --- Can I skip the T's?
    Quote Originally Posted by notw22 View Post
    Use adhesive lines Shrink tube, depending on where yer at, you can get T heat shrink as well, but that will work just fine.
  3. Thanks notw22 thanked for this post
  4. #3
    Tampa, FL
    1,336
    Found this that might be helpful. http://www.instructables.com/id/Easy-Heat-Shrink-Tee/
    Chris
    Holiday Lighting, LLC
    Your Source for Genuine Mean Well Power Supplies
    https://holiday.lighting
    https://facebook.com/holidaylightingllc
    @holidaylightin9
  5. Thanks notw22, TomL8345 thanked for this post
    Likes TomL8345 liked this post
  6. #4
    Westminter, MD
    61
  7. Thanks notw22 thanked for this post
  8. #5
    879
    or head over to your local car parts dealer and peruse their connection stuff.
  9. Thanks notw22 thanked for this post
  10. #6
    West Bloomfield, MI
    464
    If you are feeding power into the ends of the 100 pixel string, you don't need to inject in the middle. Therefore, no Ts required.
    Ed
    Happily retired
  11. Likes pixelpuppy liked this post
  12. #7
    Dallas TX
    588
    I agree. I do most of my power injection at the end of strings without T's.
  13. #8
    NM
    67
    Thanks everyone for your feedback!
    notwlights.com
  14. #9
    356
    In all actuality, if you keep you intensity down, you can run a strand of 100 pixels without power injection in the middle.
  15. #10
    Mar 2015
    100
    Quote Originally Posted by jerry72 View Post
    I will second this. I run some of mine at 40% and can go near 150 and still have around 11 volts at the end and no noticeable color change.
