Results 1 to 10 of 11
Thread: 5V Power Injection Wiring - Please Comment
    Sep 2016
    Phoenix, AZ
    13
    Default 5V Power Injection Wiring - Please Comment
    Please Comment.
    Does this look correct to you experts.
    Newbie here designing my system for 2018 implementation.
    This is the power injection design I am thinking about using to power 600, 5 Volt 2811 bullet pixels along the front eave of my house.
    Looking for feedback
    Will this work?
    Do you see anything "wrong" with it?
    Is this there a "better" way?
    Thank you soo much.......... learning everyday
    I hope I attached this image correctly
    West Bloomfield, MI
    477
    Default Re: 5V Power Injection Wiring - Please Comment
    Quote Originally Posted by Steve and Anthony View Post
    Please Comment.
    Will this work?
    Looks OK to me.
    Ed
    Happily retired
    Sep 2016
    Phoenix, AZ
    13
    Thanks Ed........... I figured someone would suggest some improvements............ either that or, as a noobie, I guess have done enough homework
    Sep 2013
    Seattle, WA
    1,084
    I used to do that, but with the combination of needing thicker copper, splitters, fuses, soldering, dark repeater pixels, rainproofing everything, I eventually gave up.
    I now just have E682 controllers every 16ft along my roofline. 5 of them covers 100 linear foot. Then I have Ray make all my lights with 10ft lead wires and I just plug them in.
    Itís easier, more reliable, simpler to troubleshoot or swap out a string, and if you solder your own controller boards, itís not really more expensive.
    Do your own math to see if this makes sense for you - if you only end up using 1 port per board it may be a bit expensive, but if you later plan to add icicles, snowflakes, flood lights etc. it may work out better.
    2017: 33069 pixels, 24 E682's. 50 A/C with 2 LOR
    2016: 21500 pixels, 24 E682's. 6 A/C with 2 LOR
    2015: 7500 pixels, 11 E682's. 35 A/C with 3 LOR
    Long Neck, Delaware
    349
    Steve as everyone has said looks good. I would get a cheap digital meter from Lowe's and try to get the output voltage as close as possible on both supplies. I have received 5 volt power supplies that were as much as .5 volts different from each other. I set the output of my 5 Volt supplies as close as I can to 5.10 volts.
    Gary
    Sep 2016
    Phoenix, AZ
    13
    Thanks deonb, Great info........I never considered using multiple controllers. I could probably use the 4 channel from Falcon and just use two ports, 50 pixels each way. I still would have to run cat 5's and 120 along the roof line to power the 4 channel controllers/power supplies; but then, I get it, its alot easier just to just plug in two strings per controller and go........... also room for easy growth, my design does not allow for any growth along the eave.......... mmmmmmmmmmmmm thanks a bunch........ gonna have to give this more thought. At least I gave myself a year to figure this out
    Gary, the Meanwell LPV 60-5 (40 Watt, constant voltage) power supplies do not come with a voltage adjustment. I just received 2 of them to practice with on friday, I have not put leads on them yet to play around (too many Thanksgiving wife honeydo's this weekend), but I will be sure to check when i get them up and running.
    Thanks for the comments.
    Delafield,WI
    249
    In this hobby of ours, there are so many options for controllers and power supplies. I've been reducing the foot print of all the "equipment" in the yard. I use an F16V2 which stays nice and comfy in the house. I try to max out the pixel count per output from the controller. I've found using RS-485 transmitter/receiver boards (very cheap on ebay) a long with cat6 cable that I can extend the signals to pretty much anywhere in my front yard. The RS-485 uses a twisted pair of wires per signal. So 3 signals and 1 power to drive the receiver boards at the end of the cable. My longest cable is about 100 feet. Last year I used 2 5V power supplies (40A & 60A) and 1 12V (33A). I run a 16 ga power cable in parallel with the strings and power inject about every 50 pixels. Using a meter, I run additional power cables where the voltage starts to dip. The cost of the power cables are much cheaper than using many power supplies or bucks. Each year I'm Adding more 12V pixels because less power injection is needed (newer 12V pixels use regulator chips instead of resistors to drop the voltage). I'll be adding a second 12V 33A power supply for this year.
    Sep 2016
    Phoenix, AZ
    13
    Thanks RogerH. Yes Im learning that there is no "best" way, just "different" ways. But these posts have given me lots to think about, separate power supplies, higher voltage power supplies/buck converters, separate controllers, differential expansion/ remote receiver boards ....... Its going to take me longer to figure out HOW I want to do it than actually DOING IT Im just glad I gave myself a year to figure this out
    BTW... What is the max length you run on your 16 ga, parallel to strings, power injection cable, it would seem like after just a couple hundred pixels the voltage drop would become fairly significant.......
    Delafield,WI
    249
    Many people comment on power injection at the beginning of a 100 pixel string and at the end. This does work BTW. Everything depends on the gauge wire used in the pixel string. My initial start with pixels was bidding for the cheapest bullet nodes I could find on ebay. The problem is you get what you pay for e.g 22 gauge wire instead of 18 gauge. The 16 gauge wire running in parallel was to compensate for this. Find a good vendor. Buy in the January/February time frame (pre-sales). I made the mistake of "assuming" pixels are pixels, WRONG. I've switched to 12V pixels from vendors in the states (they deal with the vendors in China, specs, etc). There are pros and cons to both 5V and 12V. When I started, I had a bunch of PC power supplies so 5V made a lot of sense. Hope this helps.
    Nov 2008
    Allen, TX
    86
    This year I am finally attempting to put pixels on my house. I know I'm way late but that's just how it is. In the past I had one string on the roof and one power supply and a couple arches (using led drivers) so things were simple. Now I am struggling on how I should power everything. Mainly the design of getting power from my supplies to my lights. It seems simple when you have a string of lights that connect to another but quickly gets cloudy when things aren't close enough together. Last year I bought a spool of 18awg 7 wire (solid) cable thinking I would use it. Before I start cutting wires I would love to see other's designs for where their power supplies are and the power runs so I can wrap my head around it.
    I have 1000 5v pixel bullets (500 black/500 multicolor wire), 150 5v square pixels, 750 node black pixel strips (5@5m 30leds/m waterproof sleeve) and 4 Rob-G floods. I don't have a set plan for everything yet but I am thinking the strips will be attached to pvc for my window frames (already have regular led strings on them that will be replaced) and the 500 black bullets as a start for my mega tree (boscoyo mount strips should be here any day). I have two 5v 60a 300w power supplies. I am currently using 2 renard controllers with some PX-1 adapters. Until now I mostly controlled incadescent/led strings. I have a Renzilla with 6 px-1 adapters waiting in the wings.
    I have pigtails soldered to half of my pixels and 4 of my floods so far. I have a 12v PS for my floods.
    Randy
