Thread: 50 of 200 string dont light up
    Nov 2013
    6
    Default 50 of 200 string dont light up
    I have a 200 count string of led's, the last 50 are not working. I have no repair experience with led but lots with incan. So do same principles apply that there is a bad led in that last 50 and I need an led keeper to find it or is there possibly another issue. If somebody can give answers or direct me to a page that has them I would appreciate it.
    Dec 2009
    WesternTreasure Valley, Idaho
    1,187
    Default Re: 50 of 200 string dont light up
    When I was running a show I found the LED Keeper a tool everyone should own. Sure saved me a lot of time trying to find the problem. Worth the money.
  3. Likes scootchu liked this post
  4. #3
    Nov 2013
    6
    So since there is that block in the line that I do not know what that is, diode, capacitor, resistor or whatever, could that maybe be the issue or is it more than likely an led?
  5. #4
    West Bloomfield, MI
    447
    Quote Originally Posted by eagllvr View Post
    More likely an LED or LED connection issue like corrosion on the socket.
    Ed
    Happily retired
  6. Likes Ruppro liked this post
  7. #5
    Jan 2013
    Pennsylvania
    44
    I have had both issues, corrosion in the light bulb socket and I have also lost the "blob". Corrosion has been by far the more common issue. Also the repair of the problem will be different if your lights are sealed or unsealed. The keeper comes with components you can use on a sealed set, on a set with removable bulbs you simply replace the bulb if you have a replacement. As LED bubs may be difficult to find it might be worth buying a "donor" string when you buy a set of lights.
  8. #6
    Palmdale CA
    130
    KEEP HI AND DRY
  9. #7
    Maryville, TN
    211
    Do not use the Light Keeper Pro to help repair your LED light strings, use only the LED Keeper.
    The video is wrong in using the Light Keeper Pro to repair LED Lights.
    I am the inventor of the LED Keeper and the company that makes the Light Keeper Pro bought my invention to repair LED Lights safely.
    Inventor of the "LED Keeper"
    My Videos [URL="http://www.vimeo.com/Dennischerry"]www.vimeo.com/Dennischerry[/URL]
  10. Likes NDNS00ner liked this post
  11. #8
    Jan 2010
    Nashville, TN
    908
    Quote Originally Posted by Dennis Cherry View Post
    Dennis, can I ask what value of resistor is used in the led replacement pods? I've used the two poss that were with my led keeper pro, and neglected to write down what the value of the resistors were.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    208 channels
    2 Ren 24SS / 4 REN 16SS / 2 REN 48LSD controllers
    8 Mighty Mini RGBW floods
    1 LEDTriks
    2 Helix V3 controllers and Vixen to rule them all
  12. #9
    Maryville, TN
    211
    Quote Originally Posted by mikentn View Post
    The resistor value is 330 Ohms 1/4 watt.
    You can get more Pods on Amazon.com, Ulta-Lit.com or LEDKeeper.com
