After you have setup your com port then entered the
Select output method and compile for show .
Check that you have set transport and protocol , also put a check in the active box .
when all is good status will be green . Red status will indicate issues .
You did not mention if you are using e1.31 or ethernet , if so you will need to select your Nic also prior to entering selecti output methods .
