Results 11 to 20 of 22
Thread: 36" Mega Tree Star xlights setup help
    Oct 2017
    13
    Default Re: 36" Mega Tree Star xlights setup help
    I did it!!! Yeah for me. It was the config on the star alphapix, I didn't have the correct starting DMX Universe corresponding to what was on the xlights build,
    Once I fixed that I test out fine.
    Gil I did have it wired like you mentioned but it was a config problem as I kept saying I did not know where it was wrong.
    Now my next question is that I can run the seq's in xlights perfect but in scheduler sometimes, ever few minutes, it gets glitchy with either the lights at overly flashy/twinkling? or the are all out for a few seconds.... any ideas. I'm running it on an old laptop but not that old (Intel Core 2 Duo 2.2 ghz and Win 7) and it works perfect in xlights just glitchy in scheduler?
    Thanks again for everyones input
    Jul 2015
    267
    You need to be more precise in your description of the problem. Things I can guess but can't be sure about include which scheduler are you using. Which version of XLights. When does it go wrong at the start of a song the end of a song in the middle. Is it always the same place same lights is it some lights or all lights. Specifics matter if we are going to solve problems like this.
  3. Thanks billyp203 thanked for this post
  4. #13
    Oct 2017
    13
    Random times during the show, but most of the time the lights are flashy. like they are blinking rapidly, but obviously are not suppose to. as i type i'm testing and they are flashy almost from the start, they blacked out at 1:01 for a second then came back on di
    d it again around 1:40....
    xlights 2017.14 64 bit. the current one and the matching scheduler
  5. #14
    Oct 2017
    13
    alll is perfect running direct off xlights, it only on scheduler... also tried the web interface based scheduler and it's the same
  6. #15
    Oct 2017
    13
    Reading this thread: http://doityourselfchristmas.com/for...hts-to-turn-on
    I ran check scheduler and it says:
    0 Errors and 1 warn for no password - doubt that's anything
    Output processing has nothing in it
    Matrices & Virtual Matrices are empty
    Options: nothing checked
    In log, I see today's times: [WARN] This shouldnt happen ... read [5922816] + nb_samples [4096] > _tracksize [5922816]
    looks like a few of those probably b/c I'm opening retrying and closing then doing it again...
    I also see Debug with "High Score 0" and then Xyzzy reset, initializing, closing and then reset if that means anything?
    It's Mode is Standalone, i tried the others and Master & Remote both drop the lights.
  7. #16
    Oct 2017
    13
    and here's my xlights.xschedule file
    Attached Files Attached Files
  8. #17
    Jul 2015
    267
    I would like to see the log file.
  9. #18
    Oct 2017
    13
    Here you go, thx keith
  10. #19
    Jul 2015
    267
    There definitely seems to be a problem with your star wars audio file. Maybe you could pm it to me and I will try to work it out.
    That being said your biggest issue is you are running 2017.14. That is 23 versions out of date. Hundreds of bugs have been fixed since then.
  11. #20
    Oct 2017
    13
    new .32 log
