Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 63
Thread: New Product from Holiday Lighting: 4 Port Power Fan Out/Distribution Board
    Nov 2013
    Morganton,North Carolina
    1,646
    Default Re: New Product from Holiday Lighting: 4 Port Power Fan Out/Distribution Board
    Just picked up some boards,since I already had the BOM.
    (1)Falcon F16V3
    (1)Renard SS16
    (1)Renard SS24
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Become A Supporting Member
    Falcon Christmas
    Renard Controllers
    Aug 2012
    Nova Scotia, Canada
    1,676
    Hey Chris....having a problem finalizing an order for the distribution boards.
    I can fill out all shipping info but when it comes to selecting shipping method there is nothing to select.
    I know, I know....those darn canadians always screw things up! LOL
    I have to order before NAFTA gets torn up! LOL
    Tampa, FL
    1,339
    Ahh Canadian that's a problem because shipping is very expensive. Send me an email cward@holiday.lighting and let me know what you want and I'll see what I can do.
    Chris
    Holiday Lighting, LLC
    Your Source for Genuine Mean Well Power Supplies
    https://holiday.lighting
    http://holiday.lighting/images/icons/facebook-icon.png https://facebook.com/holidaylightingllc
    http://holiday.lighting/images/icons/twitter-icon.png @holidaylightin9
    Tampa, FL
    1,339
    Quote Originally Posted by MrSmoofy View Post
    Guestimates are going to be $14 to $25 USD to ship to Canada will depend on what and how much you order.
    Chris
    41
    Here are some photos of my v2.0 boards (pardon the messy and beat-up work table). I ended up not using the solder in the kit on the lugs and used my thinner stuff, with my good Hakko iron cranked up as high as it will go. Had a bit of trouble on a few getting the lugs to stay in place while soldering, but I managed eventually. Love these little guys.
    Sent from my Pixel 2 XL using Tapatalk
    Columbus, OH
    4,263
    Nicely done !
    Soldering those lugs will get a bit easier on the next round of boards as I reduced the size of the exposed pad.
    Quote Originally Posted by DaveCorder View Post
    SF Bay Area
    782
    @MrSmoofy thanks for posting the tables with your field measurements. I am using 5v pixels and developing a new power wiring strategy and this is important to know. We all know that 5v is more energy efficient but less tolerant of (power/ground) wire length.
    I'm really very surprised to see the difference between the solid and stranded wire voltage drops. I have expected that with similar overall cross-section (similar wire gauge) the resistance per length would be very close. I'm wondering if there is something other than stranded vs solid at play here (or related to the stranded/solid difference but really a consequence rather than a cause).
    I wonder if the big drop is due to the connector/wire interface rather than the wire (length) itself. Perhaps in terminating the stranded wire, some strands were cut (effectively necking down the wire to a lower gauge at the termination. Or not all strands were captured under the connection screw?
    It would be very interesting (to me) if you could replicate the testing for the #12 stranded wire, but rather than varying the current, vary the wire length. That would then allow calculation of the resistance/length, and any constant resistance (such as at the connections). This could also be done for the solid wire. I would expect that the resistance/length is very similar between solid and stranded wire, but the constant is not.
    Tampa, FL
    1,339
    Chris
    Kansas City Missouri
    2,099
    I just noticed you added the accessories connections. Nice touch for a fan, controller, temp sensor.
  10. Likes MrSmoofy liked this post
  11. #30
    Columbus, OH
    4,263
    You betcha ! That is exactly the idea.
    Easy connection for a light use device with a simple pin header or solder the wires on.
    Another use case is for one of those inexpensive (~ $1) voltage indicators to make sure the power supply isn't dropping its voltage.
    ie: https://www.aliexpress.com/item/New-...StoreLevelAB=4
  12. Likes MrSmoofy liked this post
