Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 51
Thread: 27 Channel Controller + Vixen 3
  1. #41
    2,603
    Default Re: 27 Channel Controller + Vixen 3
    Your color issue is most likely a patching issue. Dont go by wire color. Go by what the system does and adjust the patching.
  2. #42
    May 2017
    Portugal
    37
    i gave up with 27 Channel Controller + Vixen 3 and made my own.
    http://doityourselfchristmas.com/for...685#post489685
    Best regards zelev
  3. #43
    Winter Haven Florida
    2,595
    I have 2 27ch dmx board from holiday coro and both work fine with vixen
    James WinterHaven Fl
  4. #44
    May 2017
    Portugal
    37
    Maybe my cheap dongle is/was the issue!!!
    What kind of dongle do you have TazChaLet?
    it's from holiday coro?
    Best Regards
    Zelev
  5. #45
    2,595
    Quote Originally Posted by zelev View Post
    Best Regards
    Zelev
    I have this board from HC http://www.holidaycoro.com/27-Channe...-Amps-p/25.htm and this dongle http://www.holidaycoro.com/Enttec-Pr...ongle-p/53.htm are you setting the dip switches correctly on your board
  6. #46
    May 2017
    Portugal
    37
    Maybe not....
    Ive set them up to receive data from vixen/pc and only with the first dip switch on.
    it's your board connected directly to your computer?
    Can you share your configuration?
    Best Regards
    Zelev
  7. #47
    2,595
    my dongle is connected to the usb port and the controller connects to the dongle
  8. #48
    2,595
    I see in your setup you have the baud rate set as 57600 dmx should be set at 230400 I think
  9. #49
    May 2017
    Portugal
    37
    Quote Originally Posted by TazChaLet View Post
    I will try that...
    Best Regards
    Zelev
  10. #50
    2,595
    I set mine in the setup of vixen and I also set the comm port in device manager for the port it is on
