Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Does this look right my outlets
    Oct 2017
    Buchanan, GA
    325
    Default Does this look right my outlets
    Edit post #47 should now be the correct way.
    okay, I hooked it up just to find out if it's right don't worry I'm not going to plug anything in. I still waiting to get my SSR
    but trying get this project closer. I built a encloser todsy to hold the SSR and these outlets. plan to use the socket that has all 3 leads in the box for a regular socket so I could plug my 5v power into it or a power supply or whatever I might need... I have power wire to each outlet to the next.. the lables are for the wires that will be coming from each of the 8 SSR I've cut the hot tab on all 4 outlets that's mounted so I can have 2 separate outlets on each one.. I relized at least I think i have to run a hot wire from.the one socket to the SSR board also then kinds like I did with the outlets piggy back from one ssr channel to the next one.. correct?
    I have try to read and watch videos and there are a ton of videos showing people's hooked it up but Noone really explains at least for this guy how to connect it where I 100% understsnd..
    electricity isn't something I like to play with if it was just 12v ild just try it and say heck if not right but not when comes to 110v or higher. I don't want to catch anything on fire..
    thanks muxh everyone on this site has been so helpful to everyone
    Sent from my SM-S920L using Tapatalk
    FB @ langleylights
    1,171
    Default Re: Does this look right my outlets
    it looks right from a wiring standpoint. if it were me, I would only use green for the ground. white for the neutral, black for hots. It conforms to the standard that way.
    1,171
    hold on.... do you have the relay plugs' neutrals connected to the hot side of the first plug? not right!
    Oct 2017
    Buchanan, GA
    325
    I just picked a color I guess. the left side of the outlet is connected to the left side of all the other outlets..
    the hot side I clipped the hot bar off is the side the relays hook to right?
    was hoping some the guys recently did this would see this
    FB @ langleylights
    Oct 2017
    Ohio
    37
    What the previous person is saying is that you Daisy chained your four relay outlets together on their neutral, which is correct, then you connected those four chained outlets to your feed outlets hot, this is NOT correct. Using the standard for green ground, white neutral, and black load will help keep you straight. Chain your relays neutrals to the feed neutral, chain the grounds to feed ground. Then the feed hot (black wire) goes to one of the terminals on each relay. The other terminal on each relay then goes to the hot on one outlet. At no point should a neutral connect to a hot.
    Folsom, CA, USA
    1,956
    First, let's define what the SSR switches; the Line or the Neutral.
    In the normal world you switch the LINE (black) not the neutral (white), however if the SSB switches the neutral then you are forced to use that, otherwise switch the line (black)
    Never use green for anything except ground. Buy some fresh wire from Home Depot or Lowes. Wire is cheap, life is only once.
    Use Black for your Line and White for your Neutral.
    If SSR can switch Line, Use switching Line and bring Black wire to receptacles. If you are forced to switch the Neutrals, then bring White wire from the SSR
    Brass color screws are Line (black) Silver screws are Neutral (white)
    Don't try to switch power supplies, except on for the show and off after the show. There is too much of a delay to blink flash thru power supplies.
    You say you cut the hot tabs.....did you cut the Brass tabs (hot-line-black) or the Silver tabs (neutral-white)
    In Lights Therapy
    Folsom, CA, USA
    1,956
    Quote Originally Posted by Jediosu View Post
    I also agree with this wiring issue. We can see the miss wring based on the ground location. Align all ground terminal to the bottom and you will see the receptacle with the plug is wired differently.
    In Lights Therapy
    Aug 2011
    Zephyrhills, FL
    129
    This is the setup I used in the past. Just as the others said, change out that green wire with a white one then connect it to the white wire on the outlet you don't have mounted yet. On that same outlet a black wire connected to the black wire you already have connected will then go to supply power to each of your relays. Then use black wire to make the connections to the relays from each outlet. This will make things much easier especially when making future repairs. Break the tab only on the copper screw side and leave the tab intact on the silver screw side. Each relay will connect to a single screw on the copper side of the outlet providing 2 separate outlets as the picture you have depicts.
    Oct 2017
    Buchanan, GA
    325
    I broke the tab on the copper side. and I have wire I just used green. the drop cord had green,black,white wire I didn't know what color to use this is just to find out if it's right. ever single outlet including the non mounted on has the green wire connected to the silver side of the outlet and I left the copper side open for my relays to connect.
    a friend of mine keeps trying to tell me white is hot and black is neutral but I think he's confused. I've got to get some ends to put on the wires I will use white wires in the end.
    so the wire from the group of plugs needs to go to the left side also on the separate outlet. where does the white wire from the plug in need to go then?
    FB @ langleylights
    Oct 2017
    Buchanan, GA
    325
    Quote Originally Posted by wirenut1980 View Post
    Thanks, I think i understand now. I just changed that one wire so this is right
    post #47 now should be correct.
    FB @ langleylights
