Results 1 to 8 of 8
Thread: Vixen 2 help files not displaying
    Feb 2017
    Wales
    58
    Default Vixen 2 help files not displaying
    Hi,
    I cannot get the help files to display on vixen 2 (version 2.1.1.0). If I click on 'Help' 'Contents' I get the main chapter headings and if I click on one of the + symbols I see the sub-chapters but none of them will open.
    Mike
    Colorado Springs
    3,882
    Default Re: Vixen 2 help files not displaying
    I'm not sure they are there, but have you checked the WIKI?
    Feb 2017
    Wales
    58
    The Wiki is quite good but doesn't have anything on scheduling.
    Feb 2017
    Wales
    58
    Quote Originally Posted by Mike_Parks View Post
    Sorry, should have mentioned I am particularly having problems creating a schedule. I have posted a question under 'How do I' but nothing so far.
    Sep 2007
    Iowa
    469
    Several years back.. MS found a vulnerability in xxx.chm type help files and issued a patch to disable them.
    You can manually unblock by going to the Vixen folder, right click on Vixen.chm, select properties and check unblock.
    -Craig
    Colorado Springs
    3,882
    O.K. here goes.... These are 'click on' items
    Click On -of course, open Vixen first.......
    Programs
    Manage
    '+' sign, then enter the name of your program (make one up, like - 2017 show)
    Use each sequences plug-in setup
    Click on the Program Name that just showed up in the 'Programs' area, then Drag & Drop sequences from the left pane in to the right pane
    O.K.
    Yes
    Programs
    Schedule
    Scroll down to the time you want your show to start
    Double Click in that time line
    Select Program (i.e. 2017 show)
    Repeat
    Fill in ending time
    Recurrence - then tell Vixen how often you want the program to play (you can do a separate one for weekends if you choose) enter the start date and the end date then click OK.
    Hope this helps.
    Feb 2017
    Wales
    58
    Hi Craig,
    I don't see the same options when I click on Properties, no unblock option. Surely I wouldn't be able to see the main chapter and sub chapter headings if the file was blocked.
    Mike
    Feb 2017
    Wales
    58
    Hi,
    I can set up a basic schedule but I am trying something a little more complicated - see my recent post under 'How do I' .
    I can overwrite the start time from the one selected from the drop down list but you don't seem to be able to change the end time.
    I believe you need to end one program before starting another otherwise you get a comm port error.
    Mike
