Results 1 to 2 of 2
Thread: Vixen V2 Audio sound pattern issue with new sequence setup
    Sep 2017
    43
    Default Vixen V2 Audio sound pattern issue with new sequence setup
    I'm in my first year trying to do a very basic light show and successfully managed to program a test sequence on Vixen V2. I want to create a new sequence but for one or other strange reason when I try to set a pattern (beat) on the assigned audio track (in Event Sequence Audio screen), the song does not play over the PC speaker. The timer do run but no sound is coming out. I've tried all the settings for "audio device" but nothing seems to work. I've tested my PC speaker by playing songs on an mp3 player and it had no issues. Seems like a Vixen setting/ issue.
    Your advice on getting a solution would be much appreciated.
    West Bloomfield, MI
    690
    Default Re: Vixen V2 Audio sound pattern issue with new sequence setup
    You really should be using the latest version 3.4u2. It would seem the incorrect audio device is selected on the sequencing screen but not sure if there were any issues on this in the older versions of Vixen.
    Ed
    Happily retired
