Hi,
I am building an audio file by adding various tracks on to it using Audacity. The second track I added worked just fine but I have now added a third and have a timing issue. I have inserted 3 seconds of silence between the second track and the new track exactly the same as I did between the first and second tracks. However, when I assign the music file to Vixen (2) and play the sequence the start point for the third track is around 5 seconds later than it should be.
I know I am assigning the right music file because when I 'Export' the file in Audacity I give each attempt a different file name.
Thanks for any thoughts,
Mike
