Results 21 to 30 of 36
Thread: Mega 2560 and Vixen 2.1 SSR relays flicker when vixen runs
    Morrisburg, On, Canada
    2,540
    Default Re: Mega 2560 and Vixen 2.1 SSR relays flicker when vixen runs
    Quote Originally Posted by darko886 View Post
    I actually only have 16 channels, I accidentally posted to original code prior to me changing it to 16. Should I still adjust the baud rate?
    That number of channels give 60HZ, which wouldn't be a rapid flicker. But you may try it.
    The testing of the Arduino & SSR can be done by using a "power-on" test that cycles through each channel for say 1/2 a second before it gets to start the Vixen reading stuff. The sketch (i.e. http://doityourselfchristmas.com/for...om-mode/page23 ) in post #1 uses a "test sequence" for this purpose.
    If it still flickers then it is puzzling. I haven't experienced this phenomenon.
    Are you sending a Vixen sequence of 52 channels?
    Nov 2017
    39
    The testing of the Arduino & SSR can be done by using a "power-on" test that cycles through each channel for say 1/2 a second before it gets to start the Vixen reading stuff. If it still flickers then it is puzzling. I haven't experienced this phenomenon.
    Pardon my ignorance but do you have an example of a power on test I could use? When I get home I will take pictures of my setup and video of the flicker so you see exactly what it's doing.
    2,540
    Yes, I had edited my previous reply while not realizing you sent your reply.
    Nov 2017
    39
    Awesome, thank you so much for that. With regards to what I'm sending from Vixen, I pretty much set up a test sequence where I had each channel turn on and off for a second, and then do the same to the next.
    2,540
    I was wondering if you were sending 52 vixen channels but reading 16 in the Arduino sketch. If so, then Vixen's 52 channels of data would possibly cause a flicker at 9600 baud.
    Nov 2017
    39
    Unfortunately no, I have only 16 channels in Vixen as well. Do you think the Vixen version would matter as well? I have the newest version. I'll be home in a few hours and I'll try some of your suggestions and let you know if any work.
    2,540
    No, I don't believe it is a Vixen version problem. I don't recall anyone having this issue in recent months. There have been people who claimed flicker with LEDs but they used "snubber", which in this case is a 47K 1/2 watt resistor across the SSR output where your lights connect to. But only some people had this experience.
    Since you say that your SSR indicator LED also flickers, it makes me think that the problem is more associated with your Arduino - SSR interface. Hence a "test sequence", just using an Arduino sketch without using Vixen, may help to track it down.
    Southern California
    822
    Code:
    #define MEGA_VIXEN
    //#define UNO_VIXEN
    #ifdef MEGA_VIXEN
      #define MAX_CHANNELS 52
      int channels[MAX_CHANNELS] = {2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53};
    #endif
    #ifdef UNO_VIXEN
      #define MAX_CHANNELS 18
      int channels[MAX_CHANNELS] = {2,3,4,5,6,7,8,9,10,11,12,13,A0,A1,A2,A3,A4,A5};
    #endif
    int incomingByte[MAX_CHANNELS];
    void setup()
      int i;
      Serial.begin(9600); // set up Serial at 9600 bps
      for ( i = 0; i < MAX_CHANNELS; i ++ )  pinMode(channels[i], OUTPUT);
    void loop()
      int i;
      if (Serial.available() >= MAX_CHANNELS)
        for (i=0; i < MAX_CHANNELS; i ++)      incomingByte[i] = Serial.read();
      for (i = 0; i < MAX_CHANNELS; i ++ )    analogWrite(channels[i], incomingByte[i]);
    That is the code I'm using. If I remember correctly, the baud is 9600. I did plug the -DC into the GND.
    I'm also trying to figure out if it's Vixen or the Arduino & SSR that are causing the issue. Is there a way to test the Arduino & SSR without Vixen?
    This code uses AnalogWrite to write to all of the used pins. If you are using pins other than PWM (analog), the code won't work properly. Considering that you are using Sainsmart SSRs, they probably do not support dimming, so the analogWrite won't matter anyway. I suggest using the Victor_PV sketch found here - http://doityourselfchristmas.com/for...th-Random-mode
    Victors code also has a Self-Test feature that will light the channels one at a time in order, so you can see if the MEGA/SSR is wired correctly without using Vixen.
    Kevin
    2,540
    That's good point kev, as I was just looking at the code again and noticed that too.
    The other thing about our usual "recommendation sketch" you have pointed to is to remember is to use the header "~!" (without the quotes) in Vixen Generic Serial setup.
    Edit:
    I tried a crude sketch to use the analoWrite and it did give a sort of a flicker. I used LEDs as I don't have the SSR board. I also didn't use Vixen, but a stand-alone sketch using 8 LEDs.
    Nov 2017
    39
    Thank you all for the help! LightUp, you solved it sir. I went back and checked my Vixen setup and I had 16 elements listed, but sure enough I had 48 channels listed for my controller. Changed that to 16 and no more flickering! Thank you so much, I would have never guessed that.
