Results 1 to 10 of 10
Thread: inexpensive projector that run automagically?
    Aug 2007
    MD, USA
    1,120
    Default inexpensive projector that run automagically?
    I have one of those cheap projectors from HD in my garage window and my kids love it. The only problem is that every night I have to go out and 1) turn it on 2) setup vertical rotation 3) flip it so the text is readable from the other side of the curtain 4) pick the videos and 5) setup the timer. What I would like is something that can save these settings (or maybe allow a pi to control it) and run automatically at a certain time or power up. Is there an option out there (and I don't mind buying used for this) that does this that won't cost me a million bucks?
    ~Jason
    [URL]http://www.tooz.us[/URL]
    Saint George, UT
    92
    Default Re: inexpensive projector that run automagically?
    You might be able to get a Harmony remote to run a schedule via IR. Some projectors have serial inputs for control but that may be more difficult to setup without spending quite a bit more money.
    Aug 2015
    Muskego, WI
    59
    I'm using this projector (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) and a Pi3 running Falcon FPP software. Warning, it is a cheap projector, but I found it adequate for digital effects. It can run off HDMI, VGA or SD card, but I've only used HDMI connected to the FPP. It remembers all the settings except built-in time when unplugged. You can also define a start time, stop time and source so the projector takes care of powering itself on/off. I turn it on 1 minute after FPP start and 1 minute before FPP stop.
    Aug 2007
    MD, USA
    1,120
    Quote Originally Posted by jhoybs View Post
    Thanks! Have you had any experience with trying to use it to display through a vertical window?
    ~Jason
    Mar 2017
    Indiana
    136
    I'm using this projector https://frys.com/product/8927653 for the Singing Pumpkins from inside the garage. So long as it has power, it seems to retain settings and can be scheduled to turn on and off. Similar to jhoybs, I'm running a Pi3 with FPP, which I have power up first. The projector starts up a few minutes later.
    You can see how it looks here: https://youtu.be/EwpmgIW4qvI
    Christmas 2019 Lights: https://youtu.be/e9qOPoaFV6w
    Halloween 2019 Lights: https://youtu.be/QbNE1x21gqA
    Other shows and behind the scenes: https://www.youtube.com/channel/UCg1...c85-wgbnkNiLOw
    Sep 2017
    16
    Quote Originally Posted by toozie21 View Post
    Anyone at all have vertical windows they use? My wife wants it bad and our windows are skinny and tall.
    Sent from my HTC Desire 626 using Tapatalk
    Aug 2015
    Muskego, WI
    59
    I'm using it horizontal so I'm not sure about vertical...
    Sep 2015
    Owasso, OK
    17
    I know for sure that Atmos has vertical files in most of their videos. Some they say have two horizontal files one being optimized for vertical. We recently purchased a new house and tried to get it working in very short time (2 days) but didnt have enough time to really get it done right so ended up using horizontal mode at the old house. But its doable with vertical windows just needs really fine adjustments (or at least on my windows it will). Good luck.
    Tampa, FL
    1,340
    Chris
    Holiday Lighting, LLC
    Your Source for Genuine Mean Well Power Supplies
    https://holiday.lighting
    http://holiday.lighting/images/icons/facebook-icon.png https://facebook.com/holidaylightingllc
    http://holiday.lighting/images/icons/twitter-icon.png @holidaylightin9
    Aug 2011
    Zephyrhills, FL
    129
    Quote Originally Posted by MrSmoofy View Post
    I believe that projector has a switch for Christmas and Halloween settings. There is not a way to add or remove files.
