Results 1 to 5 of 5
Thread: Need to set Renard output plugin to Com 4 in Vixen 2
    Dec 2015
    Saint Louis
    193
    Default Need to set Renard output plugin to Com 4 in Vixen 2
    Hi everyone,
    I'm using Vixen 2.0 to test a Renard SS8 board that I just hooked up. I have it set to use the Renard output plug-in
    When I run the test, I get a pop-up error message that says something about no output on Com 1. My USB to RS485 converter is on COM 4 on my Windows machine.
    Do I need to change a setting to let Vixen know that the adapter is on Com 4? If so, how do I do that?
    Ken
    2016 - Static Light Show
    2017 - 72 Renard Channels - Roughly 4,200 Lights - 3 Sequenced Songs
    2018 - Added Pixels to Rooflines
    Website: www.doyonlights.com
    You Tube: https://www.youtube.com/channel/UCQ8...yLJieEEwDto7xg
    Adding Pixel Arches, Snowflakes, and Singing Bulbs in 2019!
    West Bloomfield, MI
    671
    Default Re: Need to set Renard output plugin to Com 4 in Vixen 2
    Quote Originally Posted by kdoyon View Post
    Hi everyone,
    Ken
    Go to Setup Display and click on the controller name in the right hand column. Select the settings icon (gear) at the bottom. You should be able to select the proper port there.
    Ed
    Happily retired
    Dec 2015
    Saint Louis
    193
    For the life of me I cannot find Setup Display.
    May 2011
    Kansas
    20
    kdoyon,
    I have Vixen 2.1.3.0. Not sure if it is the same but on mine open vixen then on the left top open SEQUENCE then OPEN AN EVENT SEQUENCE or go to recent and open a sequence then in the far left top is ATTACHED PLUGINS, click on that to open it then the box to the right side should have the Renard plugin listed(If not click it in the left side box). Now in the right box click on the Renard Dimmer Modified then to the right of that is a tab PLUGIN SETUP, click that. I use protocol version 1 and check Hold Port Open, Then click on SERIAL SETUP. There you can tell Vixen what port to use and you can set baud rate ect. I hope this is what you are looking for.
    West Bloomfield, MI
    671
    Sorry, I overlooked the Vixen 2 part. I gave you the latest Vixen info.
    Ed
    Happily retired
