Results 1 to 4 of 4
Thread: Errors when trying to run my Halloween show
    Jul 2014
    Indiana
    33
    Default Errors when trying to run my Halloween show
    I have a Halloween show that I have ran since 2014. It is on the same machine/same set up as it has always been and it has always ran without fail. Two days ago I tested to ensure it all worked and again it worked without fail. However, yesterday I hooked up my FM transmitter and tried to run the show and I got an error I have never seen in HLS "Failed to Open WaveOut" Any suggestions would be much appreciated. I have checked: to ensure default audio is set correctly, channels were prepared for output etc. I also tried to run it on a different machine. But, on the 2nd machine I got a different error "Opening COM Port 3 failed with error 2" I verified COM port set up and it appeared correct to me. I honestly do not know where to start with this one. HLS has always ran my show seamlessly. I am planning to run my Christmas show off of the same PC this year also, so I usually use Halloween to help verify all is working where. Thank you in advance for any assistance/suggestions.
    -Nathan
    Mar 2008
    1,587
    Default Re: Errors when trying to run my Halloween show
    Quote Originally Posted by nsmetcalf View Post
    -Nathan
    Just a thought. Try creating a fresh/new sequence and see if it will work... I say that because I have had times where I managed to seemingly corrupt a sequence somehow and when I went back and re-sequenced the problem went away.... In my case I suspect it was something on my computer that got changed someplace and HLS was using something/file that had changed, moved, or renamed.....and it caused the sequence to not run properly.
    Springville, Utah
    517
    Have you verified that the transmitter is working? If USB, try unplugging and re-inserting after couple minutes.
    I had this problem with my transmitter yesterday - it took several tries before it started actually showing up as an audio output.
    Jimboha
    Springville, Utah
    Jul 2014
    Indiana
    33
    Quote Originally Posted by jimboha View Post
    Jimboha
    I fixed the COM port issue by simply re-asigning the COM port. However I still have not figred put the "failed to open WavOut" issue. These were 2 seperate machines so I at least have my show running. I appreciate the advice.
