Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: xLights Scheduler help - can't get lights to turn on.
    Jan 2014
    18
    Default xLights Scheduler help - can't get lights to turn on. *SOLVED*
    I'm pulling my hair out over here. This is my first year using xLights and pixels. I have built a sequence in xLights and can run it without issue from xLights. But when I try to make a playlist in xLights Scheduler, I can't get the lights to turn on. I hit 'Play Now' and can see the step is playing, I can see the network activity in Task Manager, but the lights won't turn on. What am I missing? I am using a SanDevices E6804 and XLightsPROD Ver 2017.14 32bit.
    Last edited by ucfknight98; 10-14-2017 at 08:11 AM. Reason: To add *SOLVED* to title
    Winter Haven Florida
    2,648
    Default Re: xLights Scheduler help - can't get lights to turn on.
    did you click the little light bulb that makes it output to lights?
    James WinterHaven Fl
    Jul 2015
    265
    So many things to change. First of all get yourself to .32. 14 is many many months old.
    Second are you using multicast or unicast? If you have more than one network adapter in your computer turn off the one you are not using to ensure the data goes out the right card.
    Check your show directory in schedule is the same as xlights.
    Failing all of that get over to the fb group and post when you have some time to hop into zoom and I am sure one of us will get online and get you up and going.
    Oct 2016
    Missouri
    38
    Just a thought, but when I was having issues with the scheduler it was that my computer was maxed out on RAM. I bought a PI and had no problems running my show last. Feel your pain, this is my second year in. I had some good help along the way from members on this site!
    Jan 2014
    18
    Thanks for the replies.
    1) Yes, I turned the lights bulb on.
    2) I D/L'ed 2017.32 (64-bit), no change
    3) Unicast. xLights has no issue outputting to the lights from xLights, but I can't get the scheduler to output to the lights.
    4) One network card
    5) Show directory the same
    6) Used two PC's, same results
    Add'l data:
    1) Turned off the firewall, no change.
    2) I can watch the 'Packets Received' increment on the E6804 web GUI, and the 'Packets Received' start and stop as I toggle the light bulb on/off in scheduler, so data it getting there.
    Jul 2015
    265
    Did you run check schedule.
    Have you considered popping into zoom to see if others can help.
    Jan 2014
    18
    Not going to say I really understand this, but I got it working. My xLights setup was based on hooking up strings of 25 pixels in my office for testing/learning. When I installed them on the house Wednesday, the outline wasn't in multiples of 25. So I fixed the number of pixels (nodes) in the 'layout', but never when back and fixed them in the 'setup'. With this error, lights would go on in xLights, but not xScheduler. After fixing, light went on in xScheduler too. I'm afraid this hobby may drive me to drinking (more). Thanks for the help.
  8. Likes TazChaLet liked this post
  9. #8
    Oct 2016
    Missouri
    38
    Glad you got it working. I like sequencing in Xlights, seems to be a little easier for me as a second year newbie. I would recommend getting a PI and downloading Falcon for a scheduler though. I really didn't want to spend more money either last year (jumped into this really big) but I am really glad I did. I only reset controllers and the PI once during the whole season and didn't have any problems. Good luck to you and welcome to a crazy addiction! LOL.
  10. Likes Ruppro liked this post
  11. #9
    Placerville, CA
    180
    Hey guys,
    First year in xlights. converted over from Vixen to go all pixels this year. My problem is similar. Sequence runs fine in sequencer mode, but when I run scheduler, I am getting inconsistent results. Some times it starts fine and then the lights stop outputting, or I will get a real bad flicker, or sometimes the pixel response is completely wrong (color, sequ, etc). I am trying to get my Halloween display up by tomorrow but Scheduler is FREAKING ME OUT! Any help is appreciated. Running newest version of Xlights, 64bit, 8GB ram on 64bit Win7 laptop. I don't have time to build an FPP for Halloween. I would be willing to do it for Christmas but don't even have materials. Any ideas?
  12. #10
    Jul 2015
    265
    Default Re: xLights Scheduler help - can't get lights to turn on. *SOLVED*
    Have you run check schedule?
    Can you disable all but the network card you are outputting to including wifi.
    Is your show folder correct.
