Results 1 to 6 of 6
Thread: OOps need help with pixels for 24' ChromaFlake
    Sep 2016
    9
    Default OOps need help with pixels for 24' ChromaFlake
    Okay as with may other issues this starting season outside of the cookie cutter LOR world, I made another mistake. I have purchased 8 of the 24' 2 and 3 pronged Chromaflakes. got them in today and as it turns out the 3" spaced bullet nodes are not long enough to span across the pattern without splicing. I really do not want to spice that many times so need to know what type or spacing specifically do 'I need that will work. Assuming j6 would work but would rather hear from what others have used.
    Jan 2014
    247
    Default Re: OOps need help with pixels for 24' ChromaFlake
    You can leave a null pixel in the spaces where you need more than 3 inches. I did this with my chromabulbs.
    Sent from my SM-G900V using Tapatalk
    Jan 2014
    Palm Bay, Florida
    1,401
    I used 4" on my 24" snowflake.
    Kennesaw, GA
    880
    4" works great.
    Jim Nealand
    Kennesaw, Ga
    Kennesaw, GA
    880
    4" works great. Keep in mind when ordering pixels the spacing quoted often seems to be an average and depending on where the wires enter and exit on any given pixel the spacing changes. I just always order 4" spacing and if there is a little extra wire on some props so be it.
    Jim Nealand
    Kennesaw, Ga
  6. Likes Ruppro liked this post
  7. #6
    Nov 2010
    Shreveport, LA
    107
    If you're using xlights, you can also model them any way you want, so you could use holes 1,3,5,7 etc going up the flake, then 6,4,2 coming back down....I spliced my first year before the video mapping feature came out of xlights...now it's incredibly simple...just put the lights in however they fit and let xlights map the prop for you!
