Results 1 to 4 of 4
Thread: Can I do this?
    Ga
    67
    Default Can I do this?
    Ok so I have an alphapix16 both banks running on the same PSU. My question is I have 2 props near each other and I want to use an 18awg 5 core wire. One prop is on back A and the other is on bank B. Can they share the same ground wire? Data and power both from the separate banks just shared ground.
    879
    Default Re: Can I do this?
    <not an engineer>should work. how many leds on each? your ground needs to be big enough for both props.</not an engineer>
    West Bloomfield, MI
    464
    The ground wire needs to be able to carry the sum of the currents in the two power leads.
    Ga
    67
    Cool thanks makes logical sense
