Results 21 to 30 of 32
Thread: Drilling PVC in a straight line
    Aug 2016
    8
    Default Re: Drilling PVC in a straight line
    The 12.5mm bit may work out good. Hard to say. Whichever option you choose I would just verify that you can get the pixel inserted like you want it using a reasonable amount of effort before drilling thousands of holes like I did and realizing its way too tight.
    As MrGrumpy suggested, if you are going to used a standard or fixed diamter bit like that, I would highly recommend clamping the PVC before you start drilling the holes. Any variation from perfect 90 degree entry could cause the bit to grab and either screw the hole up or screw your hand up...or maybe both. I've had a few CG1500 boxes jerked out of my hand trying the drill them with a standard bit and thinking my other hand was strong enough to hold it. Me thought wrong.
    Folsom, CA, USA
    1,956
    Quote Originally Posted by aumoenoav View Post
    Hmm yes. I can't get inches here but 1/2 should be about 12,7mm. Maybe a 13mm metal drill should do the job better than a stepping but? Dunno if 13mm get too big or not.
    Edit:
    I see I can find 12.5mm and 13mm. Is the 1/2 just too big or small (since 1/2 is 12.7mm I have to go with one that is 0.2mm smaller or one that is 0.3mm larger).
    Was thinking to use a drill bit like this: http://www.biltema.no/no/Verktoy/Skj...SS-2000016864/ it say it can be used for metall and plastic.
    For me, the 12.5mm bit is actually better than the 1/2" in my experience. Some pixel are a little harder to insert, but there are fewer, to no, loose ones.
    In Lights Therapy
    West Bloomfield, MI
    651
    Edit:
    The type of drill in your link will grab the plastic and it will not be good. Use either a step drill (something like this https://www.amazon.com/ZMZ-Titanium-...ep+drill&psc=1) or a brad point drill (something like this https://www.amazon.com/12mm-Metric-B...int+drill+bits) or diamond drill bits (something like this https://www.amazon.com/FireKingdom-D...int+drill+bits).
    Oct 2009
    Nelson (New Zealand)
    435
    My comment would be:- In my case, after drilling, I had to ream the rear holes in the pipe considerably so that the pixel could be inserted easily and cleared the pixel's front shoulder, while the front hole often required a light ream so that pixel went through and locked without too much effort. Thankfully I had a 1/4" - 1" engineering tapered reamer in my tool chest :-)
    Regarding the drill, I found, as have others, that a "normal" metal drill catches and rips the PVC about while a gold coloured step drill running at 2,400 RPM worked brilliantly once it warmed up and leaves a slight chamfer on the front of the hole for the pixel shoulder/latch to lock into if the depth is set correctly.
    Terry
    [B]"Tory Street Lights", Nelson, NZ[/B]
    [B]2013 - "Honourable Mention"[/B] - 2013 Local Christmas Lighting Competition
    [B]2013 :-[/B] 11 x Ren 64XC's - 650 Channels, 45,000+ lights. 7,000 or so LED's this year:-)
    [B]"Lucky Home" [/B]- 2012 Local Christmas Lighting Competition
    [B]2012 :-[/B] 11 x Ren 64XC's - 550 Channels, 40,000+ lights. 2,500 or so LED's for the first time :-)
    [B]2011:-[/B] 7 x Ren 64XC's - 384 Channels, 30,000+ lights - all incandescents! 2 x Commercial LED Panels (72x7)!
    [B]"Supreme Winner for 2010" [/B]Local Christmas Lighting Competition, 4 x Ren 64's - 256 Channels Controlled by Vixen - "Brilliant" :-)
    18,000 to 20,000 Lights - all incandescents! 2 x LedTricks Panels with "Pix C" interface's
    [B]2009:- [/B]128 Channels of "Hill 320", 4,000 Lights
    Folsom, CA, USA
    1,956
    Yeah; brad point, that the the name I was looking for......but they still bit the pvc. Go slow and clamp the pipe.
    I use a quick clamp..https://www.lowes.com/pd/IRWIN-QUICK...-Clamp/1205683
    In Lights Therapy
    Sep 2017
    29
    Which one of the one he linked to you was refering to?
    Of the ones, using the wood drill cant be the right choise? (sounds like it would jump heavily).
    Folsom, CA, USA
    1,956
    Post 16 I made comment to a sketch. I thought I included the Drill Bit type then, but didn't.
    Yes, am a woodcrafter so I have brad point bits. I like the brad point here so I can quickly hit the pre-marked straight line.
    You do need to drill slower holes so it doesn't bit/grab. Clamping the pvc is an absolute. Also added later the 12.5 mm bit is better over the 1/2" And that I dulled my bit. Actually filed some of the sharpness. A slightly dull blade didn't bite as much.
    In Lights Therapy
    Sep 2017
    29
    I will take a look in the store what I can find. Hopefully I can get some results out of it, but I guess the most important from what everyone is saying
    1. Use a drill press
    2. Go slow
    3. Use clamps
    NM
    85
    Here is what I did. My jig has a "channel" down the middle that fits a couple ratchet extensions through the 1/2" drilled holes and into the channel. As I drill the holes, the extension stays upright, keeping the pipe from twisting. Also to help prevent twist, I only drilled 5 foot lengths of pipe so if any teeny twist did happen, it would be corrected at the start of the next 5' pipe. I measured 2.9" from the drill bit to the right inside the channel and screwed down a 3/8" socket wrench bit so as the drilled hole passed over, it would slightly stop/drop on the socket wrench bit (to give me 2.9" spaced holes) The verticals on my house however, were 8' PVC and I did not notice any twist.
    • I used a 1/2" Twist Drill Bit (which leaves a VERY clean start hole but a weird bottom exit hole)
    ^ (I did not clamp the pipe, I just held it in place with my left hand)
    • Then flipped the PVC over and used a Step Drill bit to widen the exit hole (where I would insert the pixel)
    (I'd drill through all the PVC I had first, THEN flip them over for the step drill bit.)
    •Finally I coated the PVC with semi-gloss white paint to help prevent UV damage, brittleness and saggy aged PVC. (Only time will tell if this step was worth it.)
    Last edited by notw22; 11-06-2017 at 02:26 PM. Reason: ...added short video of PVC drilling
    notwlights.com
  10. Likes OriginalHotrodder liked this post
  11. #30
    24
    I know this is an old thread, but how are you guys connecting these to your house? How well does it perform in high winds? I have some higher and very hard to get to areas that might require a lift or hiring someone to climb. I also have a bay window that is going to be a challenge. Really looking for innovative tricks for attaching to the house.
