Results 1 to 10 of 14
Thread: Roofline Mounting
    61
    Default Roofline Mounting
    Simple things are hard when you give them too much thought.
    I want to mount PVC pipe to my dormers and gutters. On the PVC I want to drape garland, red, green and white lights. I also want to attach pixabulbs directly to the PVC (probably zip ties). My question is how would you approach mounting the PVC to a 45 degree roof line? I think it's going to be heavy and plastic roof clips will slide. I've toyed with the idea of sitting something over the peak, like a 90 degree piece of steel, letting it hang over and mounting PVC to it. Also something like a clamp that goes over the roof and under the soffit. I really don't want to punch holes in the nice the aluminum that wraps the fascia. I'm might consider doing just that if I can punch just a couple of holes and put a threaded insert into it. After Christmas I could remove bolts holding the PVC and insert a plastic cover to hide it. What would you do?
    Aug 2013
    Madison, AL
    235
    Default Re: Roofline Mounting
    I know that putting holes in the aluminum is not the ideal solution, but you might consider using something like this: http://www.holidaycoro.com/Half-Inch...Clip-p/770.htm. I'm going to give them a try this year and see how they work.
    Keith
    2016 - Added 1900 pixels (12V, WS2811) using 9 ESPixelSticks for 2 8' 180 degree trees, 2 star toppers, 2 column pixel matrices, and 3 chromabulbs
    2015 - added 900 pixels (12V, WS2811) using 2 E6804 controllers (6 arches, 6 minitrees)
    2014 - 87 channels of AC lights ran by my Arduino Light Controller
    2013 - 32 channels of AC lights ran by a simple Arduino based controller
    http://www.woodardlabs.com
    320
    For your peaks, i am sure you could use them some how. https://www.cannysystems.com/
    Western Washington
    201
    I am going to try this...
    from here about 3/4 of the way down the page
    Nov 2009
    South Jersey
    1,974
    For your gutters and gable ends I did this. Simple strapping from Home Depot. Doesn't rust, stays in place and slides under shingles.
  6. Likes Ruppro liked this post
  7. #6
    Lombard, IL
    536
    Last year I use a similar setup as you are describing. I used J-hooks for all of my pipes. Over a 10' length of pipe I put 4 hook in. I just hung the pipes from my gutters. Where I didn't have gutters I found the same 12" strapping from home depot. I made a couple of bends at the end to make sure it would not flex. Stopping at on of the big holes. I then slid the strapping under the end shingles and hooked the J-hooks to the strapping. Worked great, made my roof-line setup much easier and took half the time to set it up. Can provide pic if needed.
  8. #7
    61
    Thanks for the advice. I see a couple of things that I'll try in the next few days.
  9. #8
    Charlotte, NC
    30
    Quote Originally Posted by scootchu View Post
    Any particular method you used to bend them?
  10. #9
    Sep 2017
    7
    What exactly are those? Love the idea
    Sent from my HTC Desire 626 using Tapatalk
  11. #10
    Aug 2010
    Wilmington, NC
    1,526
    There's a UPC code on a photo above...
    Sent from my SM-G930T using Tapatalk
