Results 1 to 2 of 2
Thread: Vixen sequence conversion -> Arduino Mega 2560
    Oct 2016
    7
    Default Vixen sequence conversion -> Arduino Mega 2560
    Hey folks,
    in 2016 i used an arduino mega 2560 in combination with 3x 16 channel saintsmart relay boards. Controlled via USB and an old Asus eeePC. Also last year iam worry about the conversion from vixen sequence to the arduino. There is a tutorial about that (link below). But i can't solve the problem.
    For this christmas season i wanna make a new attempt to solve it.
    Does anybody here know, how can i convert a vixen lights sequence to the arduino mega 2560 with 54 channels (relays, HIGH LOW active)?!
    greets andre
    http://www.billporter.info/2012/10/0...n-for-arduino/
    4,848
    Default Re: Vixen sequence conversion -> Arduino Mega 2560
    While this may work (converting the sequence) it is not going to hold a lot of data. Might I suggest that you put a Renard front end on your sketch and have the PC play the sequence to the Arduino? Either that or maybe add an SD card to the Arduino to hold the sequence data.
