Results 1 to 5 of 5
Thread: Cable Gland...Rubber Gasket?
    Nov 2013
    Morganton,North Carolina
    1,414
    Default Cable Gland...Rubber Gasket?
    I see some PG7 and PG9 glands that do and some that don't have the washer. I'm talking about the gasket that goes in between the actual gland and the enclosure.Does it matter?
    (1)E682
    (1)Renard SS24
    (1)E1.31 Bridge
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    (12)ESPixel Sticks (shelby aka sporadic)
    WIKI
    Become A Supporting Member
    Xlights
    Falcon Christmas
    Southern IL
    934
    Default Re: Cable Gland...Rubber Gasket?
    None of the ones I have used have a washer between the gland and enclosure. Only the rubber piece inside that goes around the wiring. I always used some silicone around the inside and outside to help seal although im not sure how helpful that really is as it seemed most of the time the silicone didnt really stick to the enclosure. I never have any water intrusion issues though.
  3. Thanks Kev7274 thanked for this post
  4. #3
    Folsom, CA, USA
    1,454
    I use o rings
    In Lights Therapy
  5. Thanks Kev7274 thanked for this post
  6. #4
    Jan 2013
    46
    Depends on what you are doing and the IP protection you are trying preserve. I''ve had offshore installations failed because of the missing washer they take their IP68 to legitamate extremes
    supply houses usually sell them separate - nylon,fiber, and orings are all options.
    makes that extra seal on those threads running into your box.
    bdecosse
  7. Thanks Kev7274 thanked for this post
  8. #5
    Nov 2013
    1,414
    Picked some up with the gaskets just to be on the safe side.
    (1)E682
    (1)Renard SS24
    (1)E1.31 Bridge
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Xlights
    Falcon Christmas
