Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Virtual Santa..What Projector Are You Using?
    Nov 2013
    Morganton,North Carolina
    1,702
    Default Re: Virtual Santa..What Projector Are You Using?
    Suggestions?
    I like the short throw of the GT760 from what I have read.
    Quote Originally Posted by scootchu View Post
    For virtual Santa you could go cheaper. I had a 50 dollar projector for Halloween.
    Sent from my SM-G930V using Tapatalk
    (1)Falcon F16V3
    (1)Renard SS16
    (1)Renard SS24
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Become A Supporting Member
    Falcon Christmas
    Renard Controllers
    South Jersey
    2,029
    I do too, but they are fairly expensive. I bought both of mine in here. How much room do you have between the window and the wall?
    Nov 2013
    1,702
    If I go in the Living Room,around 2-3 ft. If I go with the Bedroom,then I could go up to 6ft.
    The living room is a full window,so nothing would be in the way. Bedroom window is split due to be able to raise the window up and down. Not sure if that's going to matter or not.
    (1)Falcon F16V3
    (1)Renard SS16
    (1)Renard SS24
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Falcon Christmas
    Renard Controllers
    NSW, Australia
    20
    2-3 ft you're going to need a short throw projector
    depending on which virtual Santa you're doing, you don't need a whole lot of lumens, especially if the room is reasonably dark.
    last year, my first year, I used a cheap ebay projector and a $2 white plastic tablecloth, projected onto the upstairs balcony glass doors. proved reasonably effective as it looked like Santa was wandering around in a semi-dark room, and it wasn't so obviously a projection like I've seen some videos of. but it depends what 'look' you are going for.
    remember, whichever room you use you're going to need to either leave everything set up, or set it up every night. both options have their issues.
