Results 1 to 10 of 27
Thread: Execute vixen sequence into arduino without vixen ?
    22
    Default Execute vixen sequence into arduino without vixen ?
    Hello
    Is it possible to stock the result of the execution of the vixen template (the serial Flow by example). Charge it in the arduino sketch and play without vixen ?.
    Like it we dont need vixen online and have arduino totally autonomous
    Thank you for your help.
    Envoyé de mon F3211 en utilisant Tapatalk
    Southern California
    726
    Default Re: Execute vixen sequence into arduino without vixen ?
    I don't think Arduino has enough memory to perform what you want by itself. But you could use a Rasberry Pi to accomplish that task. I am exporting the Vixen sequence to a Pi and having the Pi send it to the Arduino. That way you do not have Vixen 'online'. You do not have to use your computer to play the show. This is what a lot of people are doing for their shows.
    Kevin
    22
    Thanks. Do you have a example of how to do that With rasBerry ?
    Southern California
    726
    Search this forum for "FPP" and "RPI" and you will find an enormous amount of information. If you click on my user name and then click on threads I started, you can see the questions and successes that I have had using the Rasberry Pi and the FPP program running on the Pi. I only know a little bit right now, this will be my first year using the Pi/FPP combo. I have a working test setup right now.
    Kevin
    Southern California
    726
    what sketch are you using for your Arduino? Which Arduino board are you using? Are you using more than 1 board?
    Kevin
    22
    Hello. I'm New on Christmas Light. I use arduino uno and à sketch found on this forum.
    22
    Thanks i'll go to see
    Oct 2016
    7
    I try'd this, but no results...
    Southern California
    726
    Quote Originally Posted by ap_84 View Post
    OK, then try this link http://doityourselfchristmas.com/for...-Falcon-Player
    Kevin
    3,059
    Quote Originally Posted by nono78 View Post
    Hello
    Maybe not the Vixen format but I am pretty sure someone has done some code that can read the FPP fseq format from a file on an SD card.
