Page 16 of 22 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 213
Thread: A better distribution board
  1. #151
    Tampa, FL
    1,331
    Default Re: A better distribution board
    Now that Irma is gone and back home and on a regular work schedule I hope to finish up load testing this week. Still working with UKE on sourcing the correct switches as the ones I've gotten so far don't fit but I have more on the way from several different vendors.
    Chris
    Holiday Lighting, LLC
    Your Source for Genuine Mean Well Power Supplies
    https://holiday.lighting
    https://facebook.com/holidaylightingllc
    @holidaylightin9
  2. #152
    Nov 2013
    Morganton,North Carolina
    1,412
    Good to hear.
    I ordered switches a while back,not sure if they are going to work or not. I can send you one too see if you want. Should just cost me postge.
    Quote Originally Posted by MrSmoofy View Post
    (1)Falcon PI Player (Running the show)
    (1)E682
    (1)Renard SS24
    (1)E1.31 Bridge
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    (12)ESPixel Sticks (shelby aka sporadic)
    WIKI
    Become A Supporting Member
    Xlights
    Falcon Christmas
  3. #153
    Columbus, OH
    3,910
    So,
    Here's the trick with the switches...
    SPDT (single pole, double throw), 3 Pins (no mounting 'tabs'), and most importantly: The pin spacing needs to be: 2.54mm which is 0.1 inches.
    Not 3mm, not 2mm. Those sound real close, but they won't work. This is the same spacing as your typical pin header that you see on almost every circuit board.
    Therefore, its real easy to test any switch you may have on another PCB before you get your hands on the real deal.
    Quote Originally Posted by Kev7274 View Post
    Good to hear.
  4. #154
    Nov 2013
    1,412
    Mine says this....Terminal Length: 3mm/ 0. 12"; Pin Pitch: 2. 54mm / 1"; Main Body Size
    NO mounting tabs/
    (1)E682
    (1)Renard SS24
    (1)E1.31 Bridge
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Xlights
    Falcon Christmas
  5. #155
    Tampa, FL
    1,331
    Up to you if you want to send it, I can do a fit test and send it back with your order when they are ready. I'll PM you the address.
    Chris
    @holidaylightin9
  6. #156
    Nov 2013
    1,412
    PM replied.
    (1)E682
    (1)Renard SS24
    (1)E1.31 Bridge
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Xlights
    Falcon Christmas
  7. #157
    Nov 2013
    1,412
    (1)E682
    (1)Renard SS24
    (1)E1.31 Bridge
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Xlights
    Falcon Christmas
  8. #158
    Columbus, OH
    3,910
    NO mounting tabs/
    Sounds perfect. However, you need to test it. Chris ordered a set of switches and the pin pitch was advertised at 2.54mm but in reality it was 3mm.
  9. #159
    Nov 2013
    1,412
    I'm sending Chris one so he can verify compatability.
    Sent from my SCH-I535 using Tapatalk
    (1)E682
    (1)Renard SS24
    (1)E1.31 Bridge
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Xlights
    Falcon Christmas
  10. #160
    Columbus, OH
    3,910
    Hey Folks,
    in case you didn't notice, Chris lives in Florida and there have been some delays in testing the board.
    I expect things to pick back up very soon.
  11. Thanks DrNeutron thanked for this post
