Page 1 of 10 123 ... LastLast
Results 1 to 10 of 98
Thread: Hopefully This Is Easier to Fix
    Oct 2009
    613
    Default Hopefully This Is Easier to Fix
    Again, thanks for all the networking help to get my PI up and running wirelessly.
    I hooked up the 5X6 P10 panel and got this for a Butterfly effect.
    And this for a marquee
    Both are really off. This is how I hooked up my panels for a 5X6 setup - I added another 2 rows the same way.
    And then there is this setup - which is correct?
    I see a totally different "arrow" setup.
    I got both of the setup images from the forum matrix section.
    The xLights matrix is set up like this.
    Also, nothing is happening on the top two rows - no power or not video input i bet. I switched a ribbon cable around and that didn't help.
    I don't think its the power distort board because some of the panels that are working get power from the same board.
    Did some wire switching for diagnostics - I took a ribbon cable from output #3 of Ron's Pi Matrix adapter (which connects to the top 2 rows that don't work) and hooked it to the 2 middle rows (that do work)
    and there was no signal output.
    So I am assuming that output #3 is not working - Does anyone know which of the IC's controls the output to #3?
    But that wouldn't explain the mix up in the panel display.
    Tampa, FL
    1,336
    Default Re: Hopefully This Is Easier to Fix
    Not sure if I can help I'm just learning this myself but I would take pictures of the back of how you have the ribbon cables connected and the arrows of the panels. Next is in FPP that page is as if you are looking at it from the front so it's reversed when looking at the panels from the back.
    Chris
    Holiday Lighting, LLC
    Your Source for Genuine Mean Well Power Supplies
    https://holiday.lighting
    https://facebook.com/holidaylightingllc
    @holidaylightin9
    Oct 2009
    613
    Here's the photos of the rear.
    I switched around all of the IC's on the output board and this is what I got - entire extra row and one panel of the last row worked - could the way I have th panels oriented - front verses left cause something like this or is it an IC problems?
    Folsom, CA, USA
    1,470
    How many panels do you have, and what is their arrangement?
    Also, what sequencer are you using?
    In Lights Therapy
    Oct 2009
    613
    5 panels wide X 6 panels high. Just running a "butterfly effect in xzlights.
    This is how its set up in FPP.
    Mine be like this?
    Folsom, CA, USA
    1,470
    If your assembly is like the picture except 5W6H, then your arrows are wrong.
    Here is 5X6 for that picture and xlights.
    In Lights Therapy
    Oct 2009
    613
    So I would have to take apart the panels and re-orient them so the arrow on the panels match the arrows in your drawing - correct?
    And just for clarification - am I looking at the "back" of the panels in your drawing?
    So the top right corner (in the drawing) is actually the top left from the front?
    As always - thanks
    Folsom, CA, USA
    1,470
    Send me a picture of your panel back. I'll send you the FPP layout
    In Lights Therapy
    Folsom, CA, USA
    1,470
    Quote Originally Posted by covewi View Post
    Mine be like this?
    FYI All three of these are different.
    In Lights Therapy
    Folsom, CA, USA
    1,470
    As always - thanks
    Top left does not refer to cabling.....it tells FPP how the data will be received, then FPP will send to P10's based on output number, panel number, and arrows
    In Lights Therapy
