Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 98
Thread: Hopefully This Is Easier to Fix
  1. #51
    Oct 2009
    613
    Default Re: Hopefully This Is Easier to Fix
    This is a test file from mrGrumpy and the weird out of sync text still shows up - the upside down does not matter thats the way the file showed up.
    The next photo is also some text and the weirdness shows up everywhere.
    A video showing whats happening.
    https://youtu.be/j_F3qpRQK3I
    I read that the same thing is happening to jCook as posted 07-31-2017, 09:49 PM
    http://doityourselfchristmas.com/for...olumns-shifted
    The red circles are the three rows that show interference. Its the last row of each section. In my case its panels 6-10 of group of three.
    Also the light blue color indicates that at the very end of the 10 panel there is also some interference. This interference only shows up in those rows - not the first 5 panels of each group of three.
  2. #52
    Folsom, CA, USA
    1,469
    Quote Originally Posted by covewi View Post
    Just an FYI: my test file was built in Vixen, which is BOTTOM LEFT input. Your page is TOP LEFT. Upside down was expected. The test does shows a different sequencer does similar.
    I think I've gone as far as I can helping. You could have tweaked something in the Pi with the faulted Matrix Board, or Ron's Matrix board can't handle.
    Try FPP or Ron for further assistance.
    In Lights Therapy
  3. #53
    Oct 2009
    613
    Did some diagnostics - a single panel works correctly - but as soon as I try a 2 X1 panel matrix things go wrong.
    With the 2 X 1 setup the first half of the first panel works correctly - then the next half and the second panel all have interference when showing text.'
    You can also see some interference with any pattern.
  4. #54
    Tucson, AZ
    668
    Did you make your own risdon cables or did you buy them. I would swich out the ribbon cables and see if that is the issue. I had a similar issue.
  5. #55
    Oct 2009
    613
    I am using the ribbon cables between panels that came with the panels.
    The longer ones from the Pi came from Boscoyo - I have made every possible switch with the cables to rule them out with no luck.
    I am now wondering about the panels themselves.
    Covewi
  6. #56
    Folsom, CA, USA
    1,469
    Covewi
    Her is Vixen 2W1H Text test file in fseq - good luck
    TEST-2.zip
    I bought 2 spare panels this year from DIYLEDEXPRESS, and tested them with this test file. They run fine for me. Clean edges, and no noise.
    In Lights Therapy
  7. #57
    Oct 2009
    613
    I probably know the answer to this question but I wanted to make sure I am not missing something that may have been causing my problems.
    I have 5 X 6 (30 panel) matrix. After creating that model in xlights do I need to do anything with the Unicast or MultiCast? I am assuming no.
    Can I run a sequence from my laptop using xlights directly to the matrix?
    Could this make a difference? Is FPP not playing the xlights file correctly?
  8. #58
    Tucson, AZ
    668
    If you want to run the fpp from your pc you would put the fpp in bridge mode.
  9. #59
    Oct 2009
    613
    First - would it make any difference if I ran FPP from my PC vs. running it from the uploaded file on FPP?
    Now this is really weird - I made a second layer in xLights behind the text - as you can see the text looks fine - but as soon as the background stops the text gets weird.
    https://youtu.be/VmWk0IF4X2Y
    What the heck?
  10. #60
    Folsom, CA, USA
    1,469
    What the heck?
    Do you still have the link to the xLights Wednesday Conference- share this video with them if you don't have answer by then - 7:00 eastern start time.
    In Lights Therapy
