Results 1 to 6 of 6
Thread: max Length btw USB and Teensy to operate (Vixen data flow)
    Germany
    121
    Default max Length btw USB and Teensy to operate (Vixen data flow)
    Hi,
    Does anybody know the max length for an USB cable connected on a Vixen Laptop (USB 2.0) and a Teensy controler.
    Is there a limit in communication range, so at what range do VIXEN don't get all data out to the controler and we got mixups in the light display?
    Greetings
    Thomas
    Southern California
    665
    Default Re: max Length btw USB and Teensy to operate (Vixen data flow)
    I think the USB 2.0 specification distance is 5 meters. So I bought a 65 foot (20 M) USB extender from Monoprice last year. I connected my Arduino MEGA without any issues. They make a longer one (82 feet) as well.
    Kevin
    2,705
    Keep in mind that Vixen is an application running on a computer and is not in control of the computers ability to create a clean USB signal.
    Different computers use different chips to implement the USB interfaces. The spec is 5M (16'). You can go longer if you have a well designed interface and good cable. You can also insert USB hubs at strategic locations to get a bit more distance.
    Germany
    121
    Ok, thx for the details.
    It should be a 10m distance. Therefore I think i will run the controler next to the computer.
    Lombard, IL
    558
    Remember, if going a longer distance in USB, you may look at the extension cables. But pick one that has a repeater built in. This will keep the signal from degrading.
    7,074
    even better is an active USB over cat5 converter pair. They're similar price to USB booster/repeater cables, but you can make the cat5 yourself and make it any length you like.
    https://www.amazon.com/Monoprice-Ext...=usb+over+cat5
