Results 11 to 20 of 26
Thread: Really Need Some Network Help
    Folsom, CA, USA
    1,429
    Default Re: Really Need Some Network Help
    Quote Originally Posted by covewi View Post
    Attachment 36848
    So the IP address would be something in the "range"?
    The Netmask would be 255.255.255.0?
    The Gateway would be 192.168.1.254?
    Then I should be able to unplug the Pi from the router and access it from a computer wirelessly or wired?
    " I tried the above and made a static IP of 192.1681.149" Rebooted the PI and that IP address shows up.
    However when I disconnect the network cable from the card and try to log in wirelessly from my Mac - nothing happens.
    Why don't you just use DHCP and let FPP set everything up. Then you just address the FPP as FPP/
    You can go to MultiSync page to see the IP assigned.
    In Lights Therapy...
    Oct 2009
    603
    Did what you suggested and got this.
    Did an DNS update and restart.
    I unplugged the Pi router cable and tried to connect from the laptop wirelessly and wired using FPP/ in the browser.
    What came was an ad for a search engine. I tried both a Macbook and PC.
    Folsom, CA, USA
    1,429
    Ok, is your MAC wirelessly connected to that same router?
    If no, it must be connected to 192.168.1.xxx
    If it is, on the MAC, try typing in the FPP(Pi) addresses in to the web browser. 192.168.1.80
    Side note: I'm unclear as to why MultiSync lists your Gateway address
    Oct 2009
    603
    I can only connect with the .80 IP when the Pi is connected to the router.
    You have mail
    Folsom, CA, USA
    1,429
    From another post....I forgot this.
    If you don't know the IP(s) that FPP is using. Reboot with a powered speaker or earphone plugged into the PI. It tells you what IP it's found and uses
    Thanks aknflyer for reminding me.
    Quote Originally Posted by aknflyer View Post
    Plug a earphone in the jack, will tell you the ip when it boots.
    Folsom, CA, USA
    1,429
    You have mail
    here are copies of how I did it.....
    997
    Doesn't each Pi need it own unique Host name? He has his master and he has one for his P10.
    Your etho network (your show network) is a separate network from your wlan0 (home network)? Each having a unique subnet?
    I think he is trying to connect both to the same (home) network, which my understanding does not work.
    Folsom, CA, USA
    1,429
    Ruppro, I didn't pick up on the Master Remote setup, but if it does exist, then yes I agree he needs a different host name.
    For connecting both wlan0 and eth0 to the same network, you can do that. I do it on my test bench. Here is a MulticSync copy of FPP workbench.
    At the time of this screen shot; my desk top is displaying the 192.168.1.203 MultiSync page and my Laptop is displaying the 192.168.1.205 Multisync page.
  9. #19
    997
    guess the changed it or I need to play some more, need to get a second Pi.
  10. #20
    Oct 2009
    603
    Thank you for all your help.
    I am more confused than every - i thought building the matrix was going to be the time consuming part of this project.
    1 - on boot the FPP announced two IP addresses - 192.168.1.75 and 192.168.1.80 - I can connect from a wireless laptop to FPP using either IP address.
    This info is from my uVerse
    Does any of this help?
    Covewi
