Can anyone tell me how these compare to the falcon F-amps? Will one push data farther than the other - or are they about equal?
Got it - it's not some odd piece that needs special protection -- standard coverings work. Thanks guys.
And thanks Rob - I now have access to the sheet.
I am not familiar with uAmp, but from what I understand (correct me if I am wrong,) it's a signal conditioner.
My board is a line driver and should be used at the beginning or in the middle of the cable. However, it can be used as conditioner and used at the end, or on both ends at the same time (it will function as driver and conditioner.)
Simply put, WS2811 chip has a weak output, so you need to use line driver to "push" data over long wires. When data arrives at the end, it's distorted (not square,) so you need to "condition" it, amplify it and make it square.
THanks for that! Can you share the link to your google doc for ordering? Thanks!
Here it is, doc #5
Just trying to order 10 but can't seem to select International (Canada), the drop down only says NO.
Line 22 on spreadsheet, but I know shipping will be different.
pevely@seascape.ns.ca
Deleted
