Originally Posted by
jchuchla
The espixelpops are a 3rd party slimmed down version of the original espixelstick. The goals for it's existence is a less expensive unit that can be assembled by hand. They're not related except that the former is designed to use the same firmware as the original. It would have to be a completely new board. The SD Card feature requires the bigger ESP module than the original. So it's not a simple retrofit. It'd likely need a whole new board. Furthermore, I've never seen a SD Card slot that can be soldered by hand. So I'm not sure if that could be provided in kit form in keeping with the pixelpop concept. I think if you want those features, you should probably just buy the actual espixelstick v3 hardware.
