Results 1 to 9 of 9
Thread: Setup
    central MO
    66
    Default Setup
    How do I set up my Pi in FPP to start running lights? I don't have any special hats or cards or anything. Do I just use the GPIO connections to my relay boards and addressable led strands? I looked at Falcon site but not finding what I need. Unless I'm overlooking.
    Sent from my SM-N920R4 using Tapatalk
    Kennesaw, GA
    877
    Default Re: Setup
    Most folks use the player to talk to controllers and not to control lights direct. With a player you connect via USB or ethernet. There are some limited connectivity you can do using GPIO pins, but as I understand it you must also power your lights directly from a power supply. The Pi basically controls the data signal.
    Jim Nealand
    Kennesaw, Ga
    central MO
    66
    Default Re: Setup
    What kind of controllers do I need?
    Jan 2014
    Palm Bay, Florida
    1,392
    Default Re: Setup
    Falcon Controllers was my choice.
    central MO
    66
    Default Re: Setup
    Any other controllers that are inexpensive. I'm using single color light strands and some ws2811. Wanting on-off/fade with the singles
    1,122
    Default Re: Setup
    Any of the Renard controllers for the AC light strands (search SS8, SS16, SS24, TR16 or TR24) You can also find inexpensive Renard controller at the DIGWDF store
    For the Pixels, depending on how many you are planning on, you may want to consider the ESPixelStick, it is a wireless controller that will run one strand of pixels up to 680 total and it runs under $20, they just completed the latest group buy but should have another soon (June/July time frame) or Renard Plus has a similar device also
    Kennesaw, GA
    877
    Default Re: Setup
    Jim Nealand
    Kennesaw, Ga
  8. Likes Ruppro liked this post
  9. #8
    Gaithersburg, MD
    183
    Default Re: Setup
    I purchased a Pi 3 and my current setup has a Falcon F16v2 w/ 5 Renrad boards. On the Pi, I connect it to the Falcon ether net and leave all other connections in tacked. Then in Pi webpage I configure it as if I would on the Falcon? Is that correct or do I have to connect the Renards to a USB port to the Pi?
    2016 Migrating to Vixen 3.2
    Vixen 2.5x
    120 Channels
    2015 5 RenardSS24 @ 20,600 lights
    2014 5 RenardSS24 @ 18,600 lights
    2013 3 RenardSS24 @ 9,900 lights
    2012 2 RenardSS24 @ 6,000 lights
    2011 began researching
    www.KentlandsChristmas.com
  10. #9
    Long Neck, Delaware
    347
    Default Re: Setup
    Quote Originally Posted by amrutherford2012 View Post
    Try this link as a starting point. If you are using Vixen then you can look here to find out how to export the file to Falcon Player format. If you go to the bottom of the link page you can get the manual in a PDF format, I would print it if you can or at least save it, I look up items in this manual all the time. It is for version 1.8 but 95% of it is the same in V1.9 of the player software.
    Gary
    https://falcon-player.gitbooks.io/falcon-player-manual/content/
