Results 11 to 20 of 20
Thread: E 1.31 bridge
    1,122
    Default Re: E 1.31 bridge
    That is your Wireless adapter settings, scroll up to see the "Ethernet adapter" If it says "Media Disconnected" then there is a issue w/ the cable or the Bridge
    Quote Originally Posted by will3ishere View Post
    so made the above change and still timing out. checked ipconfig in command prompt and got thisAttachment 36589 shouldn't the ipv4 show what i entered?
    Jan 2009
    Monroe nc
    265
    Default E 1.31 bridge
    Currently have the static ip set at 192.168.1.200 and typing in the browser window 192.168.1.206
    Jan 2014
    Morganton,nc
    153
    Have you tried changing out the cable to rule that out? You can try running something like ipscan to see if the bridge is showing up on a different addres.
    Sent from my SM-G920V using Tapatalk
    1,122
    To answer your basic question, Yes if you have the bridge connected to your Ethernet port, it should show as connected assuming that the bridge is functioning correctly. If is says cable unplugged or disconnected then there is an issue be it the cable (quickest to check) or issue w/ the Bridge. The instructions did not say you had to you a crossover cable so any normal cat5 cable should work.
    Been there and read that, but that doesn't answer my question? When the bridge is plugged up to a computer will it not show as connected when looking at the local area connection tab when in the network and settings of windows 10
    2,205
    From my notes, (we use 6 of these):
    Communication problems with DIYLEDExpress e1.31 bridge.
    1. Make sure "wiznet" is properly aligned. (Opening of RJ45 is inward.)
    2. Use a known good cable with RJ45 on each end. (Standard Ethernet cable.)
    2. After full "reset" (hold "MODE" and "RESET" buttons at same time, then continue to hold the "MODE" button while you release the "RESET" button), the board's default IP address will then be 192.168.1.206.
    3. Set computer's IP address to something similar, e.g., 192.168.1.2.
    4. From a web browser on the PC, type in http://192.168.1.206.
    Make necessary changes to the board's IP address to be used on the light network.
    Save the configuration. Each line requires a save.
    Restart the bridge.
    Change PC IP address to the light network's address.
    Capt Tagert - Galaxy Quest.
    Jan 2009
    Monroe nc
    265
    Restart the bridge.
    thanks for all the help it was number one.
    made a bad assumption on which way the wiznet is installed
    Lombard, IL
    579
    Good, glad you got it working.
    2,205
    There was a reason that "mention" is in my notes.
    Glad to hear you got it working.
  9. #19
    Jan 2014
    Morganton,nc
    153
    Glad to hear you have it working.
  10. #20
    Jan 2009
    Monroe nc
    265
    now on to the next step, making it work with vixen and communicating renard controllers
