Try a slightly lower voltage. As I said, I had to go down to 4.5v before mine would program.
Ok - so I now have created my own Pickit 3 to PIC16F688 connection, I have set all of the correct setting (PIC selection/Family/voltage which is 4.87)) and I can read the PIC. When I select and load the hex and click program, I get the error:
The following areas will be programmed:
Program memory start address = 0x0, end address = 0xf3
Configure memory
Address 1 expected Value: 2846 Received: 0
Failed to program device
2017-04-30 12:04:53 - Programming Failed
Pass Count: 0
Attached is the HEX file.
Thanks all - I feel I am one step away!
2016 Migrating to Vixen 3.2
Vixen 2.5x
120 Channels
2015 5 RenardSS24 @ 20,600 lights
2014 5 RenardSS24 @ 18,600 lights
2013 3 RenardSS24 @ 9,900 lights
2012 2 RenardSS24 @ 6,000 lights
2011 began researching
[url]www.KentlandsChristmas.com[/url]
You also said you managed to "heat" the chip IIRC. You may want to try a new one.
Vixen 2.5x
120 Channels
In addition, I can read the PIC, Verify and erase the PIC. could the hex be incorrect?
Vixen 2.5x
120 Channels
If you can read the PIC then the connections are good. I would suspect the hex file.
D/l another and same results. I have the SAM file and I created a HEx and I d/l a hex from the site and still same error.
In the MPLAB IPE app, aside from voltage 4.5 and the family and device settings. Are there any other settings that I must change from the default?
Funny thing: I perform an erase and it states erase device complete, the I to a blank check and it states device is NOT blank!
Vixen 2.5x
120 Channels
Are you still using AUTO Import Hex & Write....For me, I do a File/Import Hex.....
If I get a full import then I can generally write it.
In Lights Therapy
When I program I use the IPE- there is a setting to slow down the programming and (this one is likely a red herring) another to choose what gets programmed -memory eeprom etc.
Have you tried to slow down the processes if possible? A reasonably short USB cable?
So, I have slowed down the programming, along w/ all other items. I thought I would share this. I performed a blank check on this PIC (which claimed it was not blank) then I exported the data. Below is a snippet of what was in the file.
:020000040000FA
:1000000000000000000000000000000000000000F0
:1000100000000000000000000000000000000000E0
:1000200000000000000000000000000000000000D0
(continued until)
:1043E00000000000000000000000000000000000CD
:1043F00000000000000000000000000000000000BD
:084000000000000000000000B8
:00000001FF
I then went to File, Import and selected the HEX file, this is what the log provided:
Connecting to MPLAB PICkit 3...
Currently loaded firmware on PICkit 3
Firmware Suite Version.....01.48.17
Firmware type..............Midrange
Programmer to target power is enabled - VDD = 4.500000 volts.
Target Device ID (0x0) is an Invalid Device ID. Please check your connections to the Target Device.
2017-05-02 09:48:31 -0400 - Reading...
Reading...
The following memory area(s) will be read:
program memory: start address = 0x0, end address = 0xfff
configuration memory
EEData memory
User Id Memory
Read complete
2017-05-02 09:48:37 -0400 - Read complete
2017-05-02 09:52:40 -0400 - Blank checking...
Blank Checking...
program memory
Address: 0 Expected Value: 3fff Received Value: 0
Blank check complete, device is not blank.
2017-05-02 09:52:43 -0400 - Blank check failed
Exporting hex file...
2017-05-02 09:52:57 -0400 - Hex File successfully created at C:/Users/Mikel/Desktop/PIC16F688.hex
2017-05-02 09:58:11 -0400 - Loading hex file. Please wait...
Loading code from C:\Users\Mikel\Downloads\Renard_SS_Operational_Fir mware (1).HEX...
2017-05-02 09:58:11 -0400 - Hex file loaded successfully.
2017-05-02 09:58:54 -0400 - Programming...
Device Erased...
Programming...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0xf3
program memory
Address: 1 Expected Value: 2846 Received Value: 0
2017-05-02 09:58:57 -0400 - Programming failed
Pass Count: 2
Vixen 2.5x
120 Channels
