Results 21 to 30 of 44
Thread: Pickit 3 - Target Device Issue
    3,817
    Default Re: Pickit 3 - Target Device Issue
    Device family is PIC16, not 18 and I am pretty sure you should only have three empty rows in the back. FYI: Any 1.8v setting is not going to work for the programmer on the 688 parts. They can run that low but need a higher voltage to program.
    3,817
    FYI: MPASM can talk to the PicKit directly. You do not need to export or import.
    Gaithersburg, MD
    219
    I do not have an option for Device Family PIC16F.
    2016 Migrating to Vixen 3.2
    Vixen 2.5x
    120 Channels
    2015 5 RenardSS24 @ 20,600 lights
    2014 5 RenardSS24 @ 18,600 lights
    2013 3 RenardSS24 @ 9,900 lights
    2012 2 RenardSS24 @ 6,000 lights
    2011 began researching
    [url]www.KentlandsChristmas.com[/url]
    3,817
    Click "All Families". That gets you the entire list. Scroll to the 16f688 device. Nothing will work properly if you do not get the device set properly.
    Folsom, CA, USA
    1,957
    Doesn't look like the PICkit3 can be used on your PIC16F688. Appears this requires the later "MPLAB ICD 3" programming device.
    In Lights Therapy
    Gaithersburg, MD
    219
    OK. I now have installed MPLAB X IDE and I do see the All Families option and on the device list, I selected PIC16F688.
    In the Power option, I have checked Power Target Circuit from Tool and it is set to 5v.
    I attache the PIC adapter and click on read and I get the errors in the image.
    Vixen 2.5x
    120 Channels
    3,817
    I used picKit3 on 8.92 and higher versions of the IDE
    1,425
    The PIC16F688 is the standard PIC for the SS series controllers and many other Renard controllers. It can be programed w/ the PICkit2 (I have a clone - works fine) or the PICkit3
    Gaithersburg, MD
    219
    How would I use an external power supply and load the hex onto the chip? or, what is the Pickit 3 pinout to PIC16F688 connection to bypass the PIC board.
    Vixen 2.5x
    120 Channels
    Winter Haven Florida
    3,039
    I Use mpasm to program my chips actually think it was in the program (mplab x) I downloaded I found it the easiest to use
    James WinterHaven Fl
