Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Pickit 3 - Target Device Issue
    Gaithersburg, MD
    219
    Default Pickit 3 - Target Device Issue
    Hi All,
    I picked up a PicKit 3 clone and I am using the MPLAB IDE 8.92. I have read many boards, FAQs and I feel that I am close, however, no cigar! I keep running into the Target Device ID (0x0) does not match excepted Device ID (0x420).
    The MPLAB is power is checked and set to 5v.
    On the board, I have followed the instructions for DIP 8,14,18,20: J1 on 2, all open and J7 on 2-3.
    For fun, I have tried to move the PIC around and all I get is a hot PIC and a Overcurrent logic has detected a fault condition....
    Thanks in advance for any assisatnce.
    2016 Migrating to Vixen 3.2
    Vixen 2.5x
    120 Channels
    2015 5 RenardSS24 @ 20,600 lights
    2014 5 RenardSS24 @ 18,600 lights
    2013 3 RenardSS24 @ 9,900 lights
    2012 2 RenardSS24 @ 6,000 lights
    2011 began researching
    [url]www.KentlandsChristmas.com[/url]
    Winter Haven Florida
    3,039
    Default Re: Pickit 3 - Target Device Issue
    looking at this as best as I can looks like you might have the pins not set for the chip you have
    James WinterHaven Fl
    3,814
    what device are you using?
    Nov 2013
    88
    Do you have it set to power the target?
    Gaithersburg, MD
    219
    I am trying to program my U6-U8 – PIC16F688 Microcontrollers. The Pickit 3 is a clone. I am using the MPLAB IDE v8.92 and I in the settings for Power, I have the power target circuit from pickit 3 checked at 5v.
    Vixen 2.5x
    120 Channels
    UK S80 postcode
    1,416
    Hi, I'm not a PIC guy but I have been watching some tutorials on them with a view to learning. This was on that delt with Pickit 3 issues, it may help, if not it's only 15 mins of your life wasted.
    https://www.youtube.com/watch?v=PqYY_nOIn5c
    3,814
    While it is not the cause of your current problem, I suggest you set the voltage to 4.5v. At 5v the programming was unreliable. At 4.5v I did not have any failures. I will look at the spec sheet to give you alignment when I get home from work
    Gaithersburg, MD
    219
    Thanks for the movie. I watched it and using the pickit 3 programmer I was able to d/l the OS and get the device ID on the clone pickit 3. However, when I attached the pickit adapter and chip, the app does not detect the chip. So, I am feel that the settings are incorrect. On the board, I selected "DIP 8,14,18,20:" and the jumpers are as follows: J1 on 2, all open and J7 on 2-3. I placed the chip top left is one facing the pull down locking lever. The reply I get on the application: No device detected.
    Vixen 2.5x
    120 Channels
    Folsom, CA, USA
    1,956
    Looks to me that you need to move your chip 1 slots closer to the 3M. You should have 3 slots open on the non 3M side.
    Far away from the 3M is the DIP20 - no open slots
    then up one slot is the 18 pin - one open slot
    up one slot is the 16 pin - two open slots
    now your 14 pin. - 3 open slots
    In Lights Therapy
    3,814
    hmm. To me it looked like three empty pins on the non-3m end and then the chip starting in the fourth pin on the non-3m end. The notch on the chip should be on the 3m end of the socket.
    After that you need to set the jumpers for a 14 pin chip. Then you need a total of 7 jumpers.
    J1 position 2
    J2 and J3 and J4 and J5 and J6 and J7 all need jumpers between positions 2&3
