Results 11 to 16 of 16
Thread: LED Conversion - Stumped
    Nov 2009
    Brisbane - Australia
    904
    Default Re: LED Conversion - Stumped
    Quote Originally Posted by Skunberg View Post
    There is a guy here that did it and posted a how to. I think it was 18 red LEDs using a ws chip to control them. So you could dim and on and off each led. But not pixels as it was only one color led. Blickenfer or similar I believe.
    You may be referring to the board I designed a while ago? In the end I went a different way, but here's the pages for those interested:
    http://www.da-share.com/christmas/pc710/
    http://www.da-share.com/christmas/71cm-candy-canes/
    20 character sig !!!
    Winter Haven Florida
    2,139
    sorry must have had wrong page and copied in my clipboard these were the others I found
    https://www.build.com/wintergreen-li...50583/s1049402
    James,
    The string you linked are incans not LED's.
    Protege94,
    if you are interested in converting to LED Strings and would like to shorten them, I have some of the String Shortners/Full Wave Converters I could spare. You can find out more about them in this THREAD. PM me if you are interested.
    James WinterHaven Fl
    Nov 2007
    Houston, TX (near Katy)
    751
    You could just go to Walmart and buy the single canes for 3.00 each or how ever much they are. I have 12 (10 and 2 spares) and they have worked without failure since 2009. I am replacing them with RBL's this year.
    I think you can buy 20 count LED's, saw them somewhere this past year and thought that might be useful for a small project.
    That's a feature not a bug.
    There's no charge for that.
    Jun 2016
    234
    Quote Originally Posted by TazChaLet View Post
    Im not sure if I am this committed since I would need 40 of these at almost $6 a piece.
    2016 - 32 Channels
    Tempe, AZ
    76
    Do you recall where you found these 20 ct. LED strings? I've found that not all of the 50 ct. Strings that you buy at the big box stores are splittable on the 25 ct. mark due to the way they are designed (which I don't understand yet and am still trying to figure out)
    Quote Originally Posted by Keith R View Post
    8,691
    If you're truly a glutton for punishment, you could try this:
    http://doityourselfchristmas.com/for...858#post462858
    Yes, it uses pixel technology except it's only one color and it gives you the effect you want. I have the same transparent red plastic candy canes... Making one of these takes a couple hours but in the end it's worth it.
    diychristmas.org
