Results 1 to 10 of 30
Thread: FS: Everything Must Go Round 2!
    Taylor, Michigan
    820
    Default FS: Everything Must Go Round 2!
    I have inventoried another round of the stuff I have accumulated in my 5 years in this hobby. As stated before, I am taking an unknown break from this hobby as with 4 little ones and 2 jobs along with 150" of snow every winter it has become too much at this time. I don't want to see all of this sitting around for an unknown amount of time and so I am dispersing it to the community, at what i believe to be, fair prices. Please pm me with any offers, etc. I have posted a lot of pictures for items listed, if you need other pictures let me know. You can see the display items in action here https://youtu.be/ozSVy9MRjlg
    Controllers
    -Renard Plus 32 no wires/enclosure. Brand New. 2 available ~ $100 each
    -Renard 48LSD with 12v 360W PS in CG1500 enclosure ~$80
    -Renard 48LSD with 5v 300W PS in CG1500 enclosure ~ $80
    -Renard 48LSD with 24v 200W PS in CG1500 enclosure, a few blown transistors. ~$50
    Enclosures
    -Orbit Cases 4 available, 3 are unused without gfci plugs, 1 has wire entry pvc connectors added ~$5 each
    -Rainbird enclosure ~$5
    Dumb RGB
    -12v IP68 5050 60Led/m strips in plastic tubes 33 Led's long with 4pin connector. 7 available ~$5 each
    -12v IP68 5050 60Led/m strips in plastic tubes 69 Led's long with 4pin connector. 1 available ~$10
    -12v IP68 5050 60Led/m strips in plastic tubes 39 Led's long with 4pin connector. 8 available ~$5 each
    Pixels
    -WS2811 5v square pixel module 50 count 18g multi wire. New. 1 available. ~$14
    -WS2811 12v Rectangular Pixel Module 20 count. New. 5 available. ~$13 Each
    -Silicone pixel endcaps 12 pack. 2 available. ~$1 each
    -Pixel Star. 380 pixels, 1140 channels. 60led/m 5v INK1003(WS2811 clone) IP68 strip. These are mounted on a 4' x 4' piece of 5/8" plywood at the moment. Set up with 3 waterproof input connectors on the back. I ran this without power injection off of a e6804. It was in an enclosure on top of my mega tree so the pixels/plywood have never been exposed to elements. I could probably pull the strips off the plywood if someone was interested in them like that. PM me with offers.
    LED's
    -Warm White LED mini's. 200 count per set. Green wire. Brand New. 15 available. ~$10 Each
    Strobes
    -Dirk Cheap Strobes. White, Red, Blue, Green Led's in plastic cases. These are attached to cat 5 cable, 4 strobes per cable. I ran these off of a ren48lsd. 10 wires with 4 strobes each available. ~$5 each setup
    Waterproof Connectors/Extensions
    -Green 4 wire connector. Male. 9 available. ~$0.50 each
    Power Supplies
    -12v 25W PS ~$5
    -12v 360W PS ~$15
    -12v 360W PS in CG1500 enclosure. ~$25
    Other Display Items
    -"Rockin Santa" Wireframe. 4' wide, 6' tall. Led lights. 4 channels (2 on each arm) ~$150
    -"Rockin Elf" Wirefram. 4' wide, 6' tall. Led lights. 7 channels (2-each arm, 3-"drum stick toss") ~$150
    -Christmas Train 14' long, 5' tall. PVC/incandescent rope light. ~$100
    -Blowmold Santa/sleigh with 4 reindeer. I have customized these with a vinyl coated steel cable running through all pieces so that they can "fly" between 2 trees. ~$100
    Other Stuff
    -Trendnet TE100-S8 ~$10
    -C7 stringer, green spt1 wire. 970' remaining on original roll of 1000'. ~$100
    -SPT2 extension cords with vampire plug ends, 2 tubs full. will separate ~make offer
    -Cat 5 cables, tested and functional, 1 tub full. will separate ~make offer
    2012: First year, 104 renard channels
    2013: 280 Renard Channels, 1050 Pixel Channels (2 x E6804)
    2014: Going pixel crazy!
    [URL="www.strotherfamilychristmas.com"]www.strotherfamilychristmas.com[/URL]
    Taylor, Michigan
    820
    Default Re: FS: Everything Must Go Round 2!
    more pics....
    Taylor, Michigan
    820
    more pics..
    Taylor, Michigan
    820
    more pics.
    Dallas TX
    505
    I'll take ALL the Pixabulbs and ALL the Xenon Strobes.
    Also will take all the green 3-core pigtails and extensions.
    PM sent.
    Jan 2014
    Morganton,nc
    152
    What voltage are the pixels?
    Sent from my SM-G920V using Tapatalk
    Jan 2014
    Morganton,nc
    152
    Also interested in the pixabulbs.
    Jun 2011
    1,616
    Sent a PM about 3am.. still haven't heard.. do you actually sleep? ha ha
    Feb 2017
    43
    Iwant all the clear strobes please mohorcicjeffery@gmail.com
    Taylor, Michigan
    820
    Lol I work midnights so I got off at 7am and just woke up
    Sent from my SAMSUNG-SM-G935A using Tapatalk
