Thread: Folder additions
    Mar 2008
    1,587
    Default Folder additions
    Hey All,
    I removed a channel from a folder (using channel manager) but when I went to add the channel back to the folder I can't figure out how to do it. I can remove channels from folders....NP....I can create new folders...NP....but for some reason I can't figure out what combination of keys or what the sequence is to add a channel to a folder I need to use to add a channel to a folder.
    Can someone 'splain' that so that my pea brain can replicate? I know it's probably painfully obvious but I'm drawing a blank due to my lack of intuitive reasoning....
    Aug 2012
    Nova Scotia, Canada
    1,600
    Default Re: Folder additions
    Very simple SC.
    1st you have to add a channel in channel manager.
    To the left of the new channel, you click the box and it will turn GREEN.
    Next you click PASTE TO FOLDER tab at top of channel manager screen.
    Then just click the box next to the folder you want the channel to be in and voila it is inside the folder.
    You can do this for multiple channels at once.....
    Mar 2008
    1,587
    Very simple SC.
    Thanks Phil..... I got a PM from Angus also....
    I was making a mistake that might befall others....... At first I thought I'd inadvertently moved the channel but then it dawned on me....I was trying to move a channel into a PixelPlane folder that I had missed/skipped when setting up the PP for preview.....
    It was driving me nuts....until it dawned on me that there's probably a good reason you can't copy into a PP folder....DUH!
