Results 21 to 30 of 32
Thread: Driveway Arch
    2,518
    Default Re: Driveway Arch
    Quote Originally Posted by ryanricks2010 View Post
    New to site. Look forward to browsing more on here and learning new things. currently in a predicament. maybe someone can assist to get me through this year. I have a archway over double car driveway. It is 3 sticks 1/2" pvc (I know not to strong). Last two years it worked fine with my string lights. This year i decided to up the amount of lights and have 600 led( 2- 300 sets) per stick. I have 5 ft of rebar (1 1/2 Ft in ground 3 1/2 ft above ground which slide into pvc.) I also have cross support where my sticks link together, Nothing in middle and it's sagging and not keeping the arch look. Spent a lot of time this year winding the lights around the pvc and really not looking to unwind and start over. Any ideas to strengthen and reduce sag? Appreciate any help. Ryan
    goto your local sporting goods store and talk to the fishing person. find the strongest line you can afford. Truss the arch just above minimum clearance height with several runs of line. pull them together-hard. you can also use the line to secure the arches to each other to create a little more support to help with lateral movement of you are having some.
    also pull the rebar and reset it at a steep angle.
  2. Likes ryanricks2010 liked this post
  3. #22
    Jan 2014
    So Cal
    21
    For anyone wanting to go metal arch here is a good choice for bending an arch
    http://www.buildmyowngreenhouse.com/...nders5999.aspx
  4. #23
    Sep 2022
    4
    I know you posted this 5 years ago, but wondering if you were successful in making the arches for a 30-35 foot span over a driveway.
    I tried years ago using 3/4" and it didn't make it. They sagged in the middle and that was without lights! I gave up but still want to do it. Thanks for your time
    Quote Originally Posted by Protege94 View Post
    I am looking to make an arch over my driveway for this years display. I am wondering if anyone on here has done that and they they used to build it?
    The driveway is slightly wider than a standard double wide and is about 30'-35' long.
    I think once built I will use either LED string lights or LED net lights and multiple channels, probably 6-10 channels.
  5. #24
    Jan 2021
    857
    I do an entire drive-through tunnel with 1" PVC, schedule 40 at 33.5 feet circumference. 4 guy lines. I've got one of those arches up right now, and for Thanksgiving I put a fan of lights on it and it turns into a turkey. The PVC itself has 300 pixels wrapped around it, 12V, which I power inject at both ends.
    I would love to figure out how to make it work with PEX, but so far that is just not to be. It is just too saggy.
  6. #25
    Sep 2022
    4
    Thank you for your reply. I will try the 1" Schedule 40. I'm looking to do about 4 total arches. Do you connect them together at all with "T" and "X" fittings to brace together or just use the guide wires?
  7. #26
    Jan 2021
    857
    First, a question: is your 30-35 foot "span" the diameter, or the circumference? I think you mean diameter. I am at 33.5 foot circumference, and I am borderline 1 1/4" PVC. If your PVC thickness is too big for a given arch length, that stresses out the couplers and they snap (which is highly catastrophic). You've got to hammer in the PVC into the couplers real good. But if your PVC is too thin (e.g. 1/2"), as you know it's wobbly. If your 30-35 feet is strictly for the diameter, you would be at 1 1/4" minimum; possibly 1 1/2". And you'll need probably 2 or 3 guys to set it up.
    I have tried any and all trusses to stabilize the base--mostly because I'm in the middle of a parking lot and I have 200 cars driving through. If you have access to grass on both ends, I would be okay simply relying on 4 guy wires, and affixing the PVC to 2-foot rebar on the ends. Actually, I would sleeve 3/4" PVC over the rebar, hammer in the 3/4" into the ground as well (which is not much...), then sleeving the 1 1/4" PVC over that.
    OTOH, if your arch is THAT big, you will probably want to hang stuff on top of it. That zenith is way high, >20 feet in the air. If you want to hang stuff, then the guy wires alone aren't going to cut it in the wind. For that, I use a combination of cross couplers and right-angle couplers at the ends. You just need a system of PVC at the base to form a wider base, to resist the swaying motion in the wind. I'd have to draw it out.
  8. #27
    3,382
    I do hope that the "couplers" being talked about are more than a standard EMT coupler (dual screw or dual clamp). We insert a piece of pipe (usually at least 12 inches long) just smaller than the one making the arch. A couple of tech screws to keep it from migrating inside the arch and all works very well.
  9. #28
    Jan 2021
    857
    Actually, less. A standard PVC coupler.
  10. #29
    Sep 2022
    4
    Quote Originally Posted by 1pet2_9 View Post
    The 33.5 foot is actually the span across my driveway. I also have 3 SUV's I would need to park under the arches, so it would definitely be over 40-45 feet long in PVC. I'm thinking this whole thing is just going to have to be a wish and dream, because there is no way i could do metal poles, and it seems like going to 1 1/4 or 1 1/2 will bring me more issues with straining the PVC. I already use rebar and sleeve with a smaller diameter. I have walkway arches that work well, so I may just have to stick with these. Thank you for your help.
  11. #30
    Jan 2021
    857
    No, the large size of the arch actually means you DON'T stress the PVC. At 40 feet, that means you only have to bend a 1 1/4" PVC 45 degrees over the span of 10 feet. It can handle that, no problem (more importantly, the PVC couplers can handle that). You can try it with a single 10' section.
    My bigger concern is actually having to get up on a ladder. Also the guy lines have to go out quite a ways. If you have access to metalworking, you can lose the guy lines, but it sounds like neither of us have access to that.
