Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Renard Px-1 one woes
    Jan 2009
    Monroe nc
    214
    Default Renard Px-1 one woes
    Trying to test my newly built renard PX-1 but seem to have hit a road block.
    It powers on, i can use the app, to program it, but I am unsure if I have the
    pic's programmed. Is there a way to verify that i did that correctly?
    When i try and run a sequence testing with just 50 pixels no lights work
    and the rx led just stays lit up solid. I am using a renard plus rs485 adapter
    that works with other renard controllers. The baud rate is set at 115200
    for all items that require that setting. Not sure if it is a setting in vixen that
    i dont have right, so this is my first try at pixels.
    Winter Haven Florida
    2,277
    Default Re: Renard Px-1 one woes
    what vixen are you using
    James WinterHaven Fl
    Jan 2009
    Monroe nc
    214
    version 3.3u2 build 305
    2,277
    I am not sure if the app programs the chip or if you can only reset the settings using the app I always used the pickit program on my px1s
    Jan 2009
    Monroe nc
    214
    so try reflashing the pics and then do not use the app after reprogramming?
    2,277
    no use the pickit program to load the firmware then you can use the app after that to change any settings
    2,277
    I always program mine with the firmware first not sure if yours came programmed with the actual firmware on them
    Jan 2009
    Monroe nc
    214
    no i had to programm the pic's myself
    1,925
    A few questions:
    If you unplug the cat5 cable does the rx light go out? If not, then you most likely have a badly programmed PIC.
    When the cat5 is plugged in is the FE light on? If so, then you may have the baudrate or another serial setting wrong.
    Are you sure you have vixen mapped to send data to the PX1?
    2017 adding 2 more candy canes, 7 Mid trees and a Halloween show. Removing most 2812 strips and replacing them with bullet pixel mounting strips. Replacing many buck converter waterproof bags with printed boxes.
  10. Likes TazChaLet liked this post
  11. #10
    Jan 2009
    Monroe nc
    214
    yes, when the cat5 cable is plugged in the rx light is lit up. when i unplugg it the rx light goes out. Capture.PNG and when the connection is made to the computer the set immage shows which port it is connected to. 12.PNG
