Results 1 to 10 of 30
Thread: Replacing A/C channel terminal blocks with plugs
    145
    Default Replacing A/C channel terminal blocks with plugs
    I saw a video of someone installing an SS board in an enclosure, but they had replaced the screw type terminal blocks with plugs. I think each plug had 8 wires so there was a total of 4 plugs or so. Has anyone seen this, and does anyone have an idea of what types of plugs they were and where to get them? Obviously half the plug would be soldered to the board where the terminal blocks normally go.
    2,176
    Default Re: Replacing A/C channel terminal blocks with plugs
    Do you mean the plugs were directly on the board? Interesting.
    "Never Give Up. Never Surrender!"
    Capt Tagert - Galaxy Quest.
    Al Gerdes - Christmas Lighting Nut!
    145
    Yes. Here is the youtube link: https://www.youtube.com/watch?v=F0cjvYHWbao
  4. Thanks Wayne J thanked for this post
  5. #4
    2,176
    Not exactly what I was trying to envision, but a great idea either way.
    Thanks.
  6. #5
    Eagan, Mn.
    4,059
    Phil Short is a member here, the video mentions that he made a post here with reference part numbers. So go to Phil's profile and search his posts to find the referenced post.
  7. #6
    Folsom, CA, USA
    1,467
    Are these what you are looking for. These are 4 Pin, other sizes are available. The trick is the size. These are 5MM, or the space between posts....so need 5mm spacing on circuit board.
    http://www.taydaelectronics.com/4-pi...5mm-5esdv.html
    http://www.taydaelectronics.com/4-pi...mm-5ehdrc.html
    In Lights Therapy
  8. #7
    145
    I think that's them. Funny that the titles say "4 pin" but the picture for the male shows 3 pin and the picture for the female shows 5! I'm sure they just have the wrong pictures shown. Thanks!
  9. #8
    Oct 2009
    Zanesville, OH
    48
    Note: The BOM for the Renard SS boards lists terminals with a 5.08 mm pitch. If you are wanting to substitute the screw terminals on an SS Board with plug-in terminals, you would want find some with a 5.08 mm pitch for best results.
  10. #9
    Folsom, CA, USA
    1,467
    Quote Originally Posted by cpcoaster View Post
    OK here is example of 5.08mm pitch
    http://www.ebay.com/itm/10Sets-Angel...sAAOSwNSxU0uoF
    - allow 30-45 days for delivery.
    In Lights Therapy
  11. #10
    Kansas City Missouri
    1,788
    Can this be used on the SS boards? It's really a good idea. Unscrewing 48 connections can be tedious. I did notice they had 14 position ones also.
    http://www.digikey.com/product-detai...1855-ND/124234
