Results 11 to 20 of 25
Thread: IP blocked?
    Jan 2010
    Omaha, NE
    2,029
    Default Re: IP blocked?
    The site was down for awhile in the past week and the error was DNS not found. You could have gotten this.
    Doug
    Having Fun with Wire Frames and Lights.
    www.wireframedlites.com
    Custom Hand Made In USA
    FaceBook:
    http://www.facebook.com/wireframedlites
    Phillips Family Display
    http://www.facebook.com/phillipsfamilydisplay
    West Bloomfield, MI
    651
    I am not having the issue in the OP, however, entering the IP address above does not get me to this site.
    Southern IL
    943
    Going to a certain page of the wiki put me on the blacklist several months ago, Brian got that fixed though
    Ashburn, VA
    395
    Try using tracert instead of ping. Tracert will tell you more about far you are getting and where you are getting blocked. I'm going to assume your laptop and desktop are Windows based. Open a command window and enter
    tracert doityourselfchristmas.com
    There will likely be several hops that are internal to your ISP but at some point it will transfer to doityourselfchristmas.com's ISP. Who to contact depends on where the blockage is.
    160
    I don't know what to do with this, but here is the output:
    Tracing route to doityourselfchristmas.com [96.31.73.105]
    over a maximum of 30 hops:
    1 1 ms <1 ms <1 ms DD-WRT [192.168.50.1]
    2 * * * Request timed out.
    3 7 ms 9 ms 8 ms 67.59.226.181
    4 15 ms 10 ms 10 ms ool-4353f60d.dyn.optonline.net [67.83.246.13]
    5 10 ms 9 ms 9 ms 451be027.cst.lightpath.net [65.19.114.39]
    6 11 ms 12 ms 12 ms 64.15.2.74
    7 14 ms 12 ms 11 ms te0-3-0-6.rcr21.ewr02.atlas.cogentco.com [154.54.11.77]
    8 13 ms 12 ms 11 ms be2600.rcr23.jfk01.atlas.cogentco.com [154.54.40.29]
    9 12 ms 12 ms 12 ms be2896.ccr41.jfk02.atlas.cogentco.com [154.54.84.201]
    10 18 ms 18 ms 19 ms be2806.ccr41.dca01.atlas.cogentco.com [154.54.40.106]
    11 31 ms 27 ms 28 ms be2112.ccr41.atl01.atlas.cogentco.com [154.54.7.158]
    12 30 ms 29 ms 30 ms be2847.ccr41.atl04.atlas.cogentco.com [154.54.6.102]
    13 30 ms * 31 ms 38.140.125.226
    14 * * * Request timed out.
    15 * * * Request timed out.
    16 * * * Request timed out.
    17 * * * Request timed out.
    18 * * * Request timed out.
    19 * * * Request timed out.
    20 * * * Request timed out.
    21 * * * Request timed out.
    22 * * * Request timed out.
    23 * * * Request timed out.
    24 * * * Request timed out.
    25 * * * Request timed out.
    26 * * * Request timed out.
    27 * * * Request timed out.
    28 * * * Request timed out.
    29 * * * Request timed out.
    30 * * * Request timed out.
    Trace complete.
    160
    Quote Originally Posted by didjareally View Post
    Could be something similar. I had been browsing around the wiki earlier this week. What is interesting is I can no longer get to the site from work either. I also had just browsed around the wiki from my work computer before that happened.
    Washington, Georgia
    3,271
    Most likely you got IP banned. For some reason parts of the wiki, and opening too many pages at once can cause the server to auto ban you.
    Macrosill will need your blocked IP addresses to unblock you. If you already sent those to him then he will probably get you straightened out soon.
    DIYC Links:
    [URL="http://doityourselfchristmas.com/wiki/index.php"]Christmas Wiki[/URL] | [URL="http://doityourselfchristmas.com/forums/addonchat.php"]Chat[/URL]
    Ricky, Jrd
    [COLOR="SeaGreen"]2012
    Fm-02 + Wall Wart Tamer
    2 Simple Renard 32
    15 SSROZ
    <a href="#" onclick="return(showhide(this));">Click here to show/hide my past display details ...</a>
    <script language="javascript">function showhide(anc){ //
    // traverse forward from anchor to find hidable div:
    for(; ; ){ if(!anc.nextSibling) break; if(anc.nextSibling.nodeName == "DIV") break; anc = anc.nextSibling; }//
    var Y='block', N='none', det=anc.nextSibling; //
    //fall-back plan: use named div:
    if (!det) det=document.getElementById('details'); //
    //toggle visibility:
    det.style.display=(det.style.display!=N)?N:Y; //
    //prevent page refresh:
    return false;}</script><div id="details" style="display:none;">2011
    Renard 24 v3.3 100%
    FM-02 with antenna 100%
    16' 8 channel Multi-color + Clear Megatree 100%</div>[/COLOR]
    Aug 2016
    Ypsilanti, Michigan
    28
    Are you using "Data Saver" in Chrome on your mobile device? You find it in Chrome, under Settings, near the bottom of the list. What this does is route your mobile browsing through Google, where they compare it and then send it through your data plan. The problem this causes is that some websites see all these webpage request coming from only a handful of Google owned IP addresses and assume that those IP address are trying to create a Denial of Service attack, so it blocks those IP addresses. If you tune Data Saver" off, things should work right. I get this every time on the other DIY site. I just turn off data saver and the webpage request come directly from my IP address.
    160
    Quote Originally Posted by Jrd View Post
    Thanks. I already sent to him this morning. At least we think we know the reason!
    Long Island, NY
    7,657
    Smerk's IP was blocked by the firewall. All fixed now. Anytime someone has an issue reaching the site feel free to email me at admin or support at this domain or my username at yahoo.
  11. Likes Jrd, didjareally liked this post
