Results 1 to 7 of 7
Thread: xlights not showing preview window data
    14
    Default xlights not showing preview window data
    Hello
    must be something simple i am missing but xlights isnt showing the display items while playing my generated sequence. it was working at one point but now its a dark screen unless clicking on the elements. Is there a way to get back the house preview to play the lights? its been quite time consuming creating the sequence.
    thanks
    Colorado Springs
    3,906
    Default Re: xlights not showing preview window data
    Click on View (top of screen), click on Windows, Click on House Preview
    14
    I have the house preview window up. Its just not showing the items play in the window. I have to click on the items in the sequence window in order for them to show in the house preview window. Not sure if there is a sync/refresh button. It seems like after I click on the items and rehit play from the start the items show in the window as they should. This happened when I first started building the sequence and I would have to close it down and reopen flights. Might be just my machine.
    Sent from my A0001 using Tapatalk
    Jan 2013
    Tucson, AZ
    1,014
    It could be so many things. First hit Render All and then play it.
    Didn't pay for a sig
    Jul 2015
    392
    Start with a check sequence. If render all doesn't fix it then check sequence is likely to tell you you have problems.
    14
    Thank you for the help. I will try these the next time I notice it
    Oct 2009
    San Francisco, CA
    61
    Quote Originally Posted by Sho95 View Post
    Bumping this old thread, as I had this problem. I clicked on 'render all' button, then I have up the 'Model Preview' and the 'House Preview'. windows opened. The render all did the trick. The button looks like a painters palette with red, green and blue dots on it.
