Results 1 to 2 of 2
Thread: BTA10-600 on SSROZ
    Oct 2007
    Altoona, PA
    566
    Default BTA10-600 on SSROZ
    Aside from physical trace size not being capable of handling the amperage, is there any other reason why changing out the SSR to a BTA10-600 (10Amp) on a SSROZ wouldn't work?
    Columbus, OH
    4,263
    Default Re: BTA10-600 on SSROZ
    The value that matters is the gate trigger ma rating. If it is similar to what you've had success with, then no, it doesn't matter if you go with a higher amp rated triac.
