Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Cheap Flood Light
    Nov 2015
    Milwaukee
    2,225
    Default Re: Cheap Flood Light
    Quote Originally Posted by sporadic View Post
    Highly recommend it, PETG is my go-to filament now. Durability of ABS without having to run 100c bed temps, enclosures, or deal with warping.
    You, however, can't acetone smooth or weld PETG like you can ABS.
    189
    I will have to get and try PETG.
    Check out awww.atomicfilament.com.. Their PETG is slightly more $ then companies like eSun ($33 vs $26) but its more uniform (0.03 mm or better roundness & diameter) and is made in the US.
    Quote Originally Posted by Wolfie View Post
    PETG has no odor, doesn't warp (much), doesn't need a heated bed and It doesn't absorb moisture as fast as ABS/PLA (less hygroscopic)... ABS is kind of 'old fashioned', like 3mm sized filament
    Southern California
    938
    I'd caution on using PLA given your location. I used PLA for my Halloween accents lights and they're all warped now. Will be re-doing them in PETG for next season - http://www.thingiverse.com/thing:1841988
    Quote Originally Posted by TheLost View Post
    Well, I bought some Hatchbox PETG and just can't seem to get consistent prints. What settings do you guys use? I have been using 245 print head temp, 60 bed temp, print speed 30.... Tried a whole bunch of different settings. Comes out stringy or blobby, or lifts from the bed.....
    Kevin
    Southern California
    938
    Finally got a chance to take a crappy photo of the cheap floodlights. The light housing probably does not focus/reflect the light all that much, but it looks cool!
    Kevin
    Southern California
    938
    Exclamation Re: Cheap Flood Light - UPDATED for Pixels
    I have used the floodlight design that I documented in the beginning of this thread for the last 3 years. However, I wanted to reduce the number of cables that I need to run from controllers to these RGB dumb lights, and I wanted a floodlight with more light output. Since I have pixels along the eaves where these floodlights are located, I will be changing the dumb RGB LEDs out for pixels and adding them into the data and power path. This will result in a much cleaner installation and allow me to keep them up year-around.
    Since the original design with PLA, I had tried using PETG filament but I have not been able to get the settings right on my printer. So my go to filament now is PLA+. PLA+ seems to provide a lot more strength and is less brittle than standard PLA. I end up spray painting all of the surfaces so I think they will hold up to the elements very well. Especially since they are protected by the house eaves from direct sunlight or rain.
    I have uploaded the .stl files to Thingiverse. They can be found here ===> https://www.thingiverse.com/thing:4122324. I will likely adapt the design into something that could be assembled into a larger matrix.
    Kevin
    495
    Default Cheap Flood Light
    If you’re looking for a better light output, you might also want to take a look here (basically, consider other options for better light output)
    More info:
    https://diychristmas.org/vb1/showthr...RGB-LED-WS2811
    Southern California
    938
    BWinter, your message inbox is full and won't accept my message.
    Kevin
