Page 7 of 7 FirstFirst ... 567
Results 61 to 69 of 69
Thread: 2" HDPE arches almost there
  1. #61
    Nov 2018
    Houston, Texas
    1,431
    Default Re: 2" HDPE arches almost there
    Are you connecting the strips directly to the controller and trying test patterns vs trying to do xLights/Vixen patterns? And you're sure you've got the right voltage and correct output on the controller?
    Yes directly
    Yes test patterns
    Output yes
    Double checking voltage if I can find it I know I ordered 12volt . Is it printed on light strip somewhere?
  2. #62
    Nov 2018
    Houston, Texas
    1,431
    Found it yes 12 volt correct
  3. #63
    Nov 2018
    Houston, Texas
    1,431
    Ok cause I canít get my strips test to light up anything and only saw 2 types 2811 and ge color so I wasnít sure
    Amazing how much a bad solder can ruin your day .
  4. #64
    Nov 2014
    Close to Hillsboro, OR
    509
    Got it working? A bad solder joint?
  5. #65
    Nov 2018
    Houston, Texas
    1,431
    Yes that controller was my first Diy solder controller . Guess when I tightened down the wires the negative out to lights broke loose. Cause when I applied separate ground to the injection wire the arch lit up. Reflowed the ground joint and fixed.
  6. #66
    Dec 2018
    Hull east riding of Yorkshire uk
    16
    Hi nice work they should be fine as I used 1"x1" wooden steaks for mine last year and had no issues. They do look good when lit up and working.
  7. #67
    Feb 2012
    9
    Hallo Sammy,
    Ben in nederland ook al aan het zoeken geweest, lastig.
    Wat doe jij met de kerst? Huis, tuin? Ik heb de laatste kerst in het wkz te utrecht gestaan.
    Groet
    Dick de wit
    Vianen
  8. #68
    New Jersey
    1,341
    Keep your eyes out at Lowes and HD. They've changed vendors of PEX several times in the last few years. Twice I was able to get 100' rolls of 3/4" white for $10 in the clearance area. I also got a 1/2" 300' roll for $15. After installing two new outside faucets, I've still got 260' of it I doubt I'll ever use for anything. But what a deal!
    Jeff
  9. #69
    Jun 2011
    1,902
    My original Arches are going up for sale.. since I am dark I need them no longer and they have only seen one season, I will post in the for sale section when I get that far.
