Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 144
Thread: 5V v/s 12V
    17
    Default 5V v/s 12V
    I am making a mega tree - 16 strands at 50 per.
    Should i go with 5V or 12V (I like 5V as it takes less power)
    Any advice is appreciated
    Nov 2015
    192
    Default Re: 5V v/s 12V
    5v will take less power, but you will have to inject more. unless you are dedicating a controller to the tree at which point you can run the stings directly from the board. I am planning the same tree. are you doing 2" or 3" spacing?
    Winter Haven Florida
    3,038
    are you using 1 16 port controller to run them? if it is all gonna be central to the tree I would go 5v if you plan on running them together with just a few ports you have to think about power injection on every string with the 5v but with 12v you can do 2 strings without power injection
    James WinterHaven Fl
    May 2016
    397
    What you save in power with 5v, you will pay in time, tees, and pigtails. ;)
    New Mexico
    4,122
    Seriously, why would anyone use 5v Pixels?
    3,038
    my tree is 5v no problems power inject was easy all things are contained right at tree started with 2 px1s last yr I changed it over to a 682 but left it wired the way it was why fix something that isn't broke if I went with 12v for my tree I would need to spend more on power supplies than what I had to do using 5v my house and other things that are longer runs are 12v each has its place in a show
  7. Likes angus40, mrGrumpy liked this post
  8. #7
    Nov 2015
    Milwaukee
    2,225
    Personally, I have changed over from having both 12v and 5v elements to having nothing but 12v.
    In the past 12v pixels did indeed consume substantially more power given the same output than 5v. This is because the old pixels typically used resistor networks to drop the 12v down to 5v for the chip and LED. However, this is no longer the case for the most part. All of the 12v pixels I purchased this past year operate on far less power than the 12v pixels from the past. They now contain a tiny voltage regulator now instead of a resistor network to convert 12v down to its internal voltage. This new regulator is far more efficient and less wasteful than the old method.
    So, if you are buying new 12v pixels, the power consumption is going to be more than 5v but not nearly as substantial as it used to be. With that, the offset in cost of materials for additional power injection points required for 5v pixels easily outweighs the cost for an extra PSU or so.
    My show is 100% 12v. No 5v anything left now. The only exception being that I scrapped my old 5v megatree and turned it into a halloween costume. I have remove all other 5v pixels and won't be using them except for one-off projects like the costumes and such.
    If I were starting all over today, I would choose only 12v pixels from the get go.
  9. Thanks BobBee thanked for this post
    Likes kk6ou, gstuever, azbacks, BobBee liked this post
  10. #8
    1,048
    If you have a static show then the power difference might mean something, otherwise I really don't think it amounts to much that you will notice, at least when it comes to your electric bill.
    I'm all 12v, except for p10 panels.
    Sent from my Pixel using Tapatalk
  11. #9
    Sep 2013
    Seattle, WA
    1,157
    Quote Originally Posted by Wolfie View Post
    Would be sweet if that voltage regulator can run on line voltage one day. Or even 55V would be nice.
    2021: 35000 pixels, 25 E682's. 2 Fobbles F4, 3 ADJ Hydro moving heads, 2 Chauvet Geysers.
    2019: 26000 pixels, 20 E682's. Centralized 24v power distribution.
    2018: 2000 pixels, 2 E682's. 4 LOR
    2017: 33069 pixels, 20 E682's. 50 A/C with 2 LOR
  12. #10
    New Mexico
    4,122
    Quote Originally Posted by Phrog30 View Post
    X2..........
